Balancing P-51 1400mm
  • f18fixer
    • Mar 2014
    Hey I'll be using ADMIRAL 4S 3000 mHa packs...I was wondering if anyone out there is using a pack like this and did you have to add nose weight to get the plane to balance, and if so how much ??
    Thanks for your help.....Craig
  • Sky Wolf
    Flying Ant
    • Sep 2013
    • 731
    • Irving, Texas
    Re: Balancing P-51 1400mm
    I fly my P-51 Red Tail and Dallas Darling on 3000, 3300 and 3600 packs. The recommended 3600 balances it out perfectly with no CG issues. The lighter packs usually require a little down trim in flight, but not much. Some days, depending on the weather, you don't even notice any difference.
    Hope this helps.
    • f18fixer
      • Mar 2014
      Thanks for the help, so I take it no weight was added, just trim in flight...
      Craig
