Ive Flown and love this plane, but had issues with the CG range given by the manufacturer. It states 40-45mm back from the leading edge. Trying to balance this plane in that range would make have to put more than 2oz of weight in the nose. After trying to make this happen I thought that was excesive. I found RC Informer used 2oz in the nose and that plane flew great. So putting the 2oz in the nose the plane balanced out between 50-55mm back. The plane flew great with no trim needed, and have been enjoying this little guy.
Ive also read where another pilot has flown his with out checking the balance and his flew great.SO the question is where is the correct range? how have others set up and flying gone? I know the plane flies great so it doesn't really matter but I'm a stickler for correct set up info
