Hi all,
I just got my Flyzone Select scale Corsair together, and all the control surfaces set up. My problem is the tail wheel, with the rudder servo centered, and the rudder perfectly straight, the tail wheel is cocked at an angle facing to the right. I looked at the tail wheel but I can't figure out how to adjust it so that it's in line with the rudder, (both straight). The way it is now I think it will be a bear as far as ground handeling is concerned, and the instructions don't address any tail wheel adjustments, I hope the tail wheel can be adjusted independently from the rudder so I can get both the rudder, and tail wheel lined up straight. Any help will be great appriciated.
Paul
Paul
