I have the Tigercat and have an issue with my gear. It works but my right side is a couple seconds slower then my nose gear and left gear side compared to the right. Is there a way to fix this to get the timing right so all 3 go up/down at the same time? All 3 go down/up but are not timed together.
F7F Tigercat gear issue
Tags: None
Hello, You can try, extending all three landing gear. Unplug the two that are in sync and working together. Run the slower gear up. Then plug in the two other gear and let them run up. Then, try the gear again. See if it will reset the timing so all three work the same. Best of luck! Matt Other wise, you would want to replace the slow gear. -
