I thought I’d give a little write up on my assembly of the new E-flite Commander mPd, I stole the format for this from Kloverzero. :)
Packaging:
The plane was packaged very well and nothing is able to move in box, the foam insert fits the plane and components very well. The different sizes of bolts were individually packaged and marked. The plane itself was in perfect condition, no dings or gouges and each piece was in its own protective plastic bag.
The Build:
I set all of the parts out on the conference room table at the office, it’s a nice big work space. :)
The landing gear is mounted first, two bolts and it’s on.
Next was the horizontal stabilizer. It has a spar and two bolts that hold it in position. The only issue I ran into was the spar for the horizontal stabilizer could be 1/8" shorter, I had to force the stabilizer to mate up with the fuselage with more force that I think it should have taken. One stab is about an 1/8" from being fully seated. I don't expect this will impact the way the plane flies but I may pull one stab off after I've flown it and shave 1/8" off the spar for a better fit.
The last item for assembly is attaching the wings, that was super easy and four bolts hold them on. I forgot to take a picture of the wing connectors but there is a set in the fuselage and the wings, they connect themselves when the wing is connected. If you want to remove the wing for transport it will be an easy job and there are NO wires to mess with for the flaps and ailerons.
This is a good looking plane; I cannot wait to get it in the air!
Finishing, Battery, and Balance:
I set up my DX 9 per the manual and then bound it to the plane. I verified all of the control throws and set my high, medium and low rates.
I put a 3S 3200mAh battery in the plane and got it balanced per the manual. She is ready to fly.
Closing Thought:
Other than the horizontal spar being 1/8” too long this plane went together quickly, it was an hour and 15 minutes from unboxing to being done with the plane bound and balanced. 8 bolts and no glue and she's ready to go! From everything I’ve been reading online everyone saying this is a really nice flying plane
Packaging:
The Build:
Closing Thought:
