FMS 1400mm T28 v4
  • AkumaZeto
    Achtung Stormtrooper
    • 907
    FMS 1400mm T28 v4
    So one of my skirts broke off from the strut. I tried to remove the longer pant part that also is hinged to the landing gear box. How the hell do you get these off without snapping the pin hinges? Also Motion can you guys start carrying these plastic bits separate from the entire assembly?
    AMA 1102566
  • Ron1950
    Retired ATC
    • Oct 2015
    • 887
    • brandon ms
    had the same problem so decided to take the long doors off...just take the xacto knife and score the door at the pin and it will come right off nice and clean
    • davidnovotny102@gmail.com
      Hobby Squawk Pilot
      Heated an exacto knife blade and trimmed at the pin hinge
      • bradl4648
        Your Motion RC CS Team Rep
        • 369
        All I did was use a small flat headed screwdriver and pushed and squeezed in and it popped out no breaking.
