My CTLS (which I nicknamed "Quasimodo" because of the ugly time I had with it in the beginning) has been gathering dust for over a year. Put it on the shelf after all the hassle with its nose gear constantly stripping the servo, and the nose gear housing shearing apart due to its woeful plastic construction. Very unsuited plane for a grass field in its stock form.
But recently I decided to make some major changes to get it back in the air. Here's some of what I did.
- Evicted Ken and Barbie from the cockpit to make room for completely revamped electronics.
- Grafted the spare and wider landing gear from my Freewing Pandora on to the CTLS and added 2.75" Dave Brown tires. The wider stance prevents it from tipping over so easily on grass. Big improvement!
- Put the nose gear on its own channel and gave it dual rates. Turns way better on grass.
- Added flaps
- Added bright Flytron strobe lights on the wing tips for looks and improved visibility
- All new electronics placed topside in the cockpit. New Rx, separate SBEC, separate arming plug and RX on/off switch, 420watt 1350KV motor with 10 x 7 prop, and Eagle Tree Guardian.
- Sandwiched 1/8th inch plywood plate to landing gear housing base and secured to fuse with big screws.
- Used the discontinued nose gear from the CTLS grass kit, with larger wheel. Not perfect but it will suffice.
- And finally trimmed it with adhesive vinyl to give it a completely new look!
So far flies with a lot more authority than stock - and looks funky on a fly by.
- Added flaps
