AH-1 Skyraider 1600mm
    Man this is a plane I would truly love to have
      There is a port on the main board for the retract controller box only cause it has that higher voltage
        I have been working on the B-26.... I hope we can get this sorted out! I am almost going to be forced to paint it in the SEA camo... The grey is nice, but a SPAD just has to have the jungle camo!!! :Cool:
          Dang right! That's how the spad should be!
          • benjack71
            • 346
            Originally posted by OV10
            Yes, you MUST use the gear control box. It is getting it's 7.2vdc from the main box distribution. If memory serves me right there are a couple points on the main box for led connections.
            Help is only as far away as a good photo of your connections. ;)
            Got the same plane as you and ran into the same problem. They will not tolerate over voltage at all. I am really not sure if its even supposed to be 7.2. I ended up going with a 2s life pack for it. I have had the control burn out twice now. I am certain it cant handle the extra 1.2 volts. I would bet that if you had the stock esc for it, that the voltage would be regulated to 6 volts for the control board. Needless to say I have not been flying it much. I got a voltage regulator laying around somewhere i have been intending to put in it, or if I could find the stock esc i might go that route. Ok edit this. Just found the esc for that plane on dragon hobby. Specs says its 5v
              Thank you!!! I have a Gekco 85 amp and it is set factory at 5 volts, so that may work well... I appreciate all the help from my R/C Brothers!!! :Cool:
