Flightline 1200mm Spitfilre
  • DocWhit
    • 4
    Having issue with Flaps not working. Flap servos are are all the way forward and will not engage or move. Using the plane with a Spektrum DXe with a AR610.
    Flaps are plugged into the Aux channel but are not responding at all. Everything else is working perfectly. Any ideas on what I can do to troubleshoot this issue?
    Thanks in advance for any help anyone can provide,
  • CDN_Iceman
    Older then dirt
    • Oct 2015
    • 51
    • Ottawa, Ontario, Canada
    Did you set up the flaps in your transmitter? Did you choose the correct wing type? On a DX6 and DX9 there is a second screen that you have to go into from the channel assign to set the flaps.
    I hope this gives you some ideas on what to look for.
    Check this page out as it might help
    • DocWhit
      • 4
      CDN_Iceman...Thank you for the info. I am new to this and it is my first warbird... I was not aware of the flap setup in the controller. Do you happen to know if you can set this on the controller directly or do I have to get the cable and software download?
      Appreciate the help and feedback.
      • CDN_Iceman
        Older then dirt
        • Oct 2015
        • 51
        No you do not need a cable to set the flaps up. You are just programming the settings in the transmitter and then this will be transferred to the receiver via the RF signal.
        Jeff
        • DocWhit
          • 4
          ok I am back.... so a quick update. I had to get the cable and the programming app for the DXe controller. the AUX 1 switch was disabled. I fixed the setting for that and then tried to test everything out. now when I turn on the transmitter and plug up the battery to the spitfire.... wait for it.... NOTHING.
          It has a single beep that repeats and the motor twitches slightly each time it beeps. I have tried to re-initialize the throttle and it does not change anything. Can someone tell me what I am missing with this....I know I am new to this, but it seems like i am making this harder than it has to be.
          • CDN_Iceman
            Older then dirt
            • Oct 2015
            • 51
            Have you rebound the transmitter to the receiver again? I don't if you need to but it is worth a try. Maybe stop by one of your local hobby shops and beg for help. Don't forget to make a purchase or head out to one of your local flying clubs for help.
            Just a thought
            Jeff
            • DocWhit
              • 4
              appreciate all the info... after re-binding the plane a second time everything is good to go and working properly.
              just a note to anyone else who has a Spektrum DXe transmiiter: I bought 2 of them and both cam with the AUX1 setting disabled.
