FMS 1400mm T-28 Wing Tip lights
  • dsmize2011
    • 3
    For some reason when ever I plug the lights into the elevator channels like the manual states. The Lights work but, the elevator stops responding. It does this even if only one of the wing tips are plugged in. Any help would be appreciated.
    Thanks, Dan
  • Lon
    • Jul 2014
    • 1202
    • Miles, Iowa
    Re: FMS 1400mm T-28 Wing Tip lights
    Hmmmm...I have several planes with the nav lights going to a 3y servo wire, which plugs into the elev port on the receiver. Have never had that issue. Of course you made sure when connecting servo wire leads, they was orientated correctly ie; black to black...
    Lon
    • dsmize2011
      • 3
      Wont lie first plane that Ive had that was more than 4 channels haha. I went through and made sure the wires are all matched and they are. The female connectors are the normal Brown yellow orange but, the male counter part for the LED lights are only two pronged and are black and red any idea what way they should be plugged in. Either way seems to still knock out the elevator function.
      • Lon
        • Jul 2014
        • 1202
        • Miles, Iowa
        black to brown....
        Lon
        • dsmize2011
          • 3
          Ha sweet that worked .... I swear I tried that but I guess not thanks for the troubleshooting help.
          • Lon
            • Jul 2014
            • 1202
            • Miles, Iowa
            <smiley image="anim_claps.gif"/>
            Lon
