I use FoamTac. Clean off as much as possible, of the original white glue from the servo first. Use a razor blade being careful not to slice into the wires.
FoamTac is the best glue for gluing foam. It stays flexible and will move with the foam. Epoxy or any hard setting glue will break at the joint because it can't flex.
Will do thank you. Nice that you was with a real Old Crow.
