Douglas C-47 1800mm (70.8") Wingspan - ARF from Nexa - NXA1012-001
The Douglas C-47 Skytrain or Dakota (RAF, RAAF, RCAF, RNZAF, and SAAF designation) is a military transport aircraft developed from the civilian Douglas DC-3 airliner. It was used extensively by the Allies during World War II and remained in front-line service with various military operators for many years.
The Nexa Douglas C-47 is a 70" wingspan electric scale series warbird, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes painted pilot, antenna and other scale details. The large battery hatch affords ample room for either electric or gas setups. To complete the scale appeal of this C-47, the model includes electric retracts and scale struts. Impress at your flying field with this iconic stunner!
Fully Covered and Detailed The Nexa Douglas C-47 comes fully covered including simulated panel lines, rivets, nomenclature and weathering detail. |
Scale Details Throughout There is no shortage of scale details with this C-47 including split flaps, painted pilot, electric retracts and metal main struts. |
Prehinged and Installed Control Surfaces All control surfaces come out of the box fully prehinged and installed for your convenience. |
Impressive Size Yet Easy To Transport To add to the array of scale detail, the Nexa C-47 comes with a 70" wingspan but the wings are easy to remove for transport. |
- Complete Balsa and lite-ply construction for rigidity and durability
- Covered from tip to tail in scale details including weathering, printed simulated panel lines and rivets
- Fiberglass cowlings for strength and durability
- The hand-painted pilot is ready for your added cockpit details
- All control surfaces come out of the box pre-hinged and installed for convenience
- Large battery hatch allows for your chosen electric or gas setup
- Nexa Douglas C-47 1800mm (70.8") Wingspan - ARF
- Electric retracts, wheels and struts
- Fuel tank, hardware and servo trays
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 2x Brushless outrunner motors - we recommend the Admiral GP2 3520-950kV Brushless Motor Multi-Pack (2 Motors)
- 2x 45 Amp brushless ESC - we recommend the ZTW Mantis 45A ESC with 5A SBEC Multi-Pack (2 ESCs)
- 4x standard servos for ailerons, elevator and rudder - we recommend the Hitec HS-85BB High Torque Micro Servo Airplane Multi-Pack (4 Servos)
- 4x standard 9g servos for flaps - we recommend FOUR of the Hitec HS-55 9g Micro Servo
- TWO 3 Cell 11.1V 5000 mAh LiPo Batteries - we recommend TWO of the Admiral 5000mAh 3S 11.1V 50C LiPo Battery with EC5 Connector
- 1x standard and 1x reverse electric propellers - we recommend APC 10x7 Thin Electric Propeller - Black and APC 10x7 Thin Electric Pusher Propeller - Black
- 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
PRODUCT SPECIFICATIONS:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 6+ HOURS
Model Scale | 1/16 |
Wingspan | 1800mm / 70.8in |
Length | 1200mm / 47.2in |
Weight | 3175.15g / 112oz |
CG (Center of Gravity) | 100-110mm from the leading edge of the wing's root |
Power System | 2x 950kV Brushless outrunner motors (required) |
Electronic Speed Control | 2x 45A (required) |
Propeller / EDF | 1x 10x7 standard and 1x 10x7 reverse electric propellers (required) |
Servos | 45g metal gear standard: left aileron, right aileron, elevator, rudder 9g metal gear standard: left outboard flap, left inboard flap, right outboard flap, right inboard flap |
Landing Gear | Electric retractable (included) |
Required Battery | TWO 3 Cell 11.1V 5000 mAh LiPo Batteries (required) |
Required Radio | 6+ Channel (required) |
Ailerons | Yes |
Elevator | Yes |
Rudder | Yes |
Flaps | Yes |
Lights | No |
Hinge Type | Nylon |
Material | Balsa and light plywood |
Skill Level | Intermediate |
Build Time | 6+ Hours |
Recommended Environment | Outdoors |
