https://www.ebay.com/itm/124219941763
wonder if this would work.
I'll go look at the place you just provided.
Bancroft 1/16 scale LCM3 Landing Craft
yea im not having any luck finding something to replace it with. might try ebayLeave a comment:
Muffinman,
Let me know what ESC you plan to use. Most of the marine ESC 's I found with high AMP ratings are for brushless motors.
right now i think im just gonna replace the ESC with something a little better. eventually i will convert it to brushless . what were your run times on the provided battery?
Thanks, the crew are 21st century toys ultimate soldier 1/18 figures they used to sell at walmart/toys R us. They aren't really correct but they look pretty good and the size is pretty much indistinguishable from 1/16. They're easy to find on ebay etc. and pretty cheap. The tank (if anyone cares) is a hybrid with a Matotoys M4a1 (cast hull) upper and a henglong M4a3 lower and running a clark board for the electronics. This is not a direct swap and takes some effort to make work. The running gear and tracks that come with the matotoys sherman are awful and won't last.
I ran the LCM-3 a lot yesterday and found it performs very well with the stock electronics. It moves at a decent speed and nothing got hot or gave any trouble. No leaks after being on the water for a couple hours. I even used it to rescue other model boats that where stranded out in the lake and it makes a great pusher.
Schmitty
bryanLeave a comment:
SchmittyLeave a comment:
Too bad this seems to be default pattern with included electronics in RTF,RTR packages from China. Cheap, poor quality, unreliable electronics that works for minutes then quit . I really hope I will not have this issue with the 1/200 Yamato I bought few days ago. Multiplex (Germany) RTF/RTR is entirely different. Their elctronics are name brand that can be used over and over again. I would not mind paying another 100 USD that I know they will work. DaiLeave a comment:
yep same issue quality control sucks over seas i guess lol. im looking now on how i want to get it all done . but i know for sure im replacing the props , the ESC and probley gonna go with brushless duel 380s and water cool everything.Leave a comment:
I've had an issue with my battery connector as well. One pin keeps popping out so I may install XT60sLeave a comment:
I am ordering the HL Sherman R/C to go into this craft. It is going a big tank and no wonder expensive. DaiLeave a comment:
Really want to upgrade the props from plastic to metal anybody know what size and types I would need. Also need to upgrade the electronics too.Leave a comment:
Hello all,
Would this work for the LC? I would need to add some additional weight as it is plastic. Thanks Dai
https://www.ebay.com/itm/US-Stock-1-...97.m4902.l9144
https://www.amazon.com/Heng-Long-Con...-3&tag=mh0b-20Leave a comment:
You will need to seal the model so the water does not wash the weathering off. If you use enamel based paint, you do not need to seal. I am sure you know but this will benefit to those new to the modeling techniques. Mine LC will arrive tomorow. Likely I will order the R/C tank to go with it or 60 1/16 army guys. DaiLeave a comment:
