Wave Chopper 2.0 Green 595mm (23.4") Racing Boat from Kyosho - RTR - KYO40211T1
Wave Chopper 2.0 Blue 595mm (23.4") Racing Boat from Kyosho - RTR - KYO40211T2
Kyosho brings the fun back to the water with the revival of the Wave Chopper, originally released in 2001! To upgrade the new Wave Chopper 2.0 with modern RC technology and performance, a redesigned rudder, stern tube and motor mount in the 1/6th hull with new rider figure combine with the latest RC components.
Optimal torque from the G14L water cooled 550 class motor works perfectly with the large capacity Kyosho Speed House KA60-91W speed controller to deliver crisp acceleration and racy performance while reducing heat loss. Styrene floats provide buoyancy that make the hull unsinkable, even if it is not completely waterproof.
As both hull and rider are pre-assembled, simply install 4 X AA batteries (sold separately) into the transmitter, charge the included NiMH battery, and mount the rider figure to start making a splash! The Wave Chopper 2.0 brings the fun of marine sports to everyone with this compact package!
Rudder Protection Kick up rudder protects both the rudder and hull from unexpected contact and delivers smooth turning performance. Built in water intake channels water into the cooling jacket on the motor for effective cooling. |
| Quick and Smooth Acceleration Optimal angle of the stern tube along the bottom of the hull reduces drive resistance allowing the fully submerged propeller to generate quick and smooth acceleration. |
Quality Power System Pre-installed 550 class G14L motor is fitted with a water cooling system to prevent heat loss. High rigidity suspended motor mount maximizes drive efficiency and easy maintenance. |
| RTR For Immediate Fun! 7.2V 2200mah battery and USB delta peak charger are included with the pre-assembled hull and 2.4ghz transmitter. Simply install 4XAA batteries (Not included) into the transmitter and charge the battery, then this model can be enjoyed by anyone. |
- RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
- All Electronics are pre-installed
- Fully Painted and Detailed
- Zero assembly required --Get underway in minutes!
- Extensively detailed and hand finished
- Rated for calm ponds, pools, and lakes appropriate for RC Boats
- Kyosho Wave Chopper 2.0 Green 595mm (23.4") Racing Boat - RTR
- Syncro KT231P+ transmitter
- Injection molded boat stand
- Pre painted figure
- Hex wrenches 1.5 & 2.5mm
- Spanner 4.0 & 5.5mm
- Antenna tube
- 7.2V 2200 mAh Ni-MH battery and USB delta peak charger
- PVC tape for waterproofing
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH - we recommend Admiral AA NiMH 2600mAh rechargeable batteries
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOUR
| Scale | N/A |
| Length | 595mm / 23.4in |
| Width | 220mm / 8.6in |
| Height | 350mm / 13.7in |
| Hull Material | ABS |
| Battery | 7.2V 2200mAh |
| Battery Quantity | 1 |
| Battery Connector | T |
| Motor | 550 class G14L Brushed Motor |
| Motor Quantity | 1 |
| Propeller Material | Plastic |
| Contra-Rotating Propeller | No |
| ESC | N/A |
| ESC Waterproof | Splash-Proof |
| ESC Quantity | 1 |
| Radio | Wheel |
| Receiver Channels | 2 |
.png)
