Official Bancroft 950mm Alpha Extreme Deep V Racer RTR Thread
    Alpha Red Brushless 950mm (37.4") Extreme Deep V Racer from Bancroft - RTR - BNC1040-001
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    The largest Bancroft speedboat at more than 3’ long, the Alpha delivers the presence, speed, handling, and stability that only an offshore Deep-V hull design can provide in an ultimately powerful, brushless, Ready To Run (RTR) package. Open the box, charge the included battery packs (yes, there are two battery packs included!!) with the provided charger, install your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for amazing speed and razor-sharp maneuverability right out of the box without any additional adjustment. The Bancroft Alpha sports an attractive, hi-visibility trim scheme that accentuates its speed and performance potential.
    For an Alpha in the alternate yellow color scheme, click here.
    Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Alpha can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 2S batteries, and battery charger.
    Water-Cooled Brushless Horsepower
    Instantaneous acceleration and unsurpassed reliability are delivered by the included brushless water-cooled outrunner motor, coupled to a monster 5.0mm flex-cable drive system for maximum efficiency.
    Extraordinarily Complete
    The Alpha includes stainless, adjustable turn fins, polished metal racing propellers for 4S and 6S use, tools, and accessories. Simply add 4 AA alkaline or rechargeable NiMH batteries and you’re ready to run!
    CAD-designed Hull
    The Alpha’s ABS plastic hull is digitally-optimized to deliver outstanding performance and razor-sharp handling in most any water conditions. A convenient boat stand is also included for when the boat is in dry dock!
    • RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
    • All Electronics are pre-installed
    • Fully Painted and Decorated
    • Rated for ponds or calm lakes appropriate for RC Boats
    • Bancroft Alpha Red 950mm (37.4") Extreme Deep V Racer - RTR
    • 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
    • Brushless, water-cooled motor drive system, pre-installed, with XT90 battery connectors
    • Heavy-Duty Steering servo, pre-installed
    • 2x 2S 7.4V 5000mAh LiPo Battery (Series)
    • 2S Battery Charger
    AGE LEVEL :14 and up
    SKILL LEVEL :advanced
    BUILD TIME :30 minutes
    Scale N/A
    Length 950mm / 37.4in
    Width 260mm / 10.2in
    Height 210mm / 8.3in
    Hull Material ABS
    Battery 2x 2S 7.4V 5000mAh LiPo Batteries in series
    Battery Quantity 2
    Battery Connector XT90
    Motor Brushless outrunner, water-cooled
    Motor Quantity 1
    Propeller Material Metal
    Contra-Rotating Propeller No
    ESC 90A Brushless
    ESC Waterproof Yes
    ESC Quantity 1
    Radio Wheel
    Receiver Channels 4
    This thread is for both red and yellow and any colored Alpha 950mm boats.
    • Woohoo\o/
      • Feb 2020
      • 186
      • Cape coral Florida
      Is this the same model as the inception sold by hobbyking?
        Do these have self recovery?
        • Kevdog1
          • Jun 2025
          I’m looking to swap out the motor and esc for more power and speed. Has anyone done this yet?
