Alpha Red Brushless 950mm (37.4") Extreme Deep V Racer from Bancroft - RTR - BNC1040-001
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
The largest Bancroft speedboat at more than 3’ long, the Alpha delivers the presence, speed, handling, and stability that only an offshore Deep-V hull design can provide in an ultimately powerful, brushless, Ready To Run (RTR) package. Open the box, charge the included battery packs (yes, there are two battery packs included!!) with the provided charger, install your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for amazing speed and razor-sharp maneuverability right out of the box without any additional adjustment. The Bancroft Alpha sports an attractive, hi-visibility trim scheme that accentuates its speed and performance potential.
For an Alpha in the alternate yellow color scheme, click here.
Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Alpha can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 2S batteries, and battery charger.
Water-Cooled Brushless Horsepower Instantaneous acceleration and unsurpassed reliability are delivered by the included brushless water-cooled outrunner motor, coupled to a monster 5.0mm flex-cable drive system for maximum efficiency. |
Extraordinarily Complete The Alpha includes stainless, adjustable turn fins, polished metal racing propellers for 4S and 6S use, tools, and accessories. Simply add 4 AA alkaline or rechargeable NiMH batteries and you’re ready to run! |
CAD-designed Hull The Alpha’s ABS plastic hull is digitally-optimized to deliver outstanding performance and razor-sharp handling in most any water conditions. A convenient boat stand is also included for when the boat is in dry dock! |
- RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
- All Electronics are pre-installed
- Fully Painted and Decorated
- Zero assembly required --Get underway in minutes!
- Rated for ponds or calm lakes appropriate for RC Boats
- Bancroft Alpha Red 950mm (37.4") Extreme Deep V Racer - RTR
- 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
- Brushless, water-cooled motor drive system, pre-installed, with XT90 battery connectors
- Heavy-Duty Steering servo, pre-installed
- 2x 2S 7.4V 5000mAh LiPo Battery (Series)
- 2S Battery Charger
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH - we recommend Admiral AA NiMH 2600mAh rechargeable batteries
AGE LEVEL :14 and up
SKILL LEVEL :advanced
BUILD TIME :30 minutes
Scale | N/A |
Length | 950mm / 37.4in |
Width | 260mm / 10.2in |
Height | 210mm / 8.3in |
Hull Material | ABS |
Battery | 2x 2S 7.4V 5000mAh LiPo Batteries in series |
Battery Quantity | 2 |
Battery Connector | XT90 |
Motor | Brushless outrunner, water-cooled |
Motor Quantity | 1 |
Propeller Material | Metal |
Contra-Rotating Propeller | No |
ESC | 90A Brushless |
ESC Waterproof | Yes |
ESC Quantity | 1 |
Radio | Wheel |
Receiver Channels | 4 |
