Official Bancroft 640mm Bullet V3 Offshore Deep V Racer RTR Thread
    Bullet V3 Brushless 640mm (25.2") Offshore Deep V Racer from Bancroft - RTR - BNC1037-001
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    More than 2’ long, the Bancroft Bullet V3 delivers the size, speed, handling, and stability that only an offshore Deep-V hull design can provide in a powerful, brushless, Ready To Run (RTR) package. Open the box, charge the included battery packs (yes, there are two battery packs included!!) with the provided charger, install your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for amazing speed and razor-sharp maneuverability right out of the box without any additional adjustment. The Bancroft Bullet V3 sports an attractive, hi-visibility trim scheme that accentuates its speed and performance potential.
    Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the BulletV3 can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 2S battery, and battery charger.
    Water-Cooled Brushless Horsepower
    Instantaneous acceleration and unsurpassed reliability are delivered by the included brushless water-cooled outrunner motor, coupled to a monster 4.0mm flex-cable drive system for maximum efficiency.
    Extraordinary Metal Running Hardware
    A CNC-machined aluminum rudder provides precise control and handling, while the 3-bladed polished metal racing propeller delivers maximum forward thrust in any water conditions!
    CAD-designed Hull
    The Bullet’s ABS plastic hull is digitally-optimized to deliver outstanding performance and razor-sharp handling in most any water conditions. A convenient boat stand is also included for when the boat is in dry dock!
    2.4GHz Pistol Grip Transmitter
    An adjustable, reliable, interference-free radio system ensures that the Bullet is always under your control at distances of up to 100M (300’).
    • RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
    • All Electronics are pre-installed
    • Fully Painted and Decorated
    • Rated for ponds or calm lakes appropriate for RC Boats
    • Bancroft Bullet V3 640mm (25.2") Offshore Deep V Racer - RTR
    • 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
    • Brushless, water-cooled motor drive system, pre-installed, with XT60 battery connectors
    • Heavy-Duty Steering servo, pre-installed
    • 2S 7.4V 4000mAh LiPo Battery x 2
      2S Battery Charger
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :15 minutes
    Scale N/A
    Length 640mm / 25.2in
    Width 180mm / 7.1in
    Height 160mm / 6.3in
    Hull Material ABS
    Battery 2S 7.4V 4000mAh LiPo Battery
    Battery Quantity 2
    Battery Connector XT60
    Motor Brushless 2815 outrunner, water-cooled
    Motor Quantity 1
    Propeller Material Metal
    Contra-Rotating Propeller No
    ESC 60A Brushless
    ESC Waterproof Yes
    ESC Quantity 1
    Radio Wheel
    Receiver Channels 4
