Official Bancroft 360mm Searider V4 Offshore Catamaran Racer RTR Thread
    Searider V4 Brushed 360mm (14.2") Offshore Catamaran Racer from Bancroft - RTR - BNC1035-001
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    The Bancroft Searider V4 offers the speed, handling, and stability that only an offshore racing catamaran hull design can deliver in a convenient, Ready To Run (RTR) package. Open the box, charge the included battery with the provided charger, your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for balanced speed and maneuverability out of the box without any additional adjustment. The Bancroft Searider V4 sports a clean, functional trim scheme that accentuates its speed and performance potential.
    Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Searider V4 can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 2S battery, and battery charger.
    Quality Electronic Components
    Impressive acceleration and sustainable high speeds are delivered by a water-cooled brushed marine 390 motor and reliable 15A marine ESC. The included 2S 7.4V 800mAH battery and convenient charger deliver high performance and extended run times, while the compliant and secure top hatch gasket keeps the insides dry.
    CAD-designed Hull
    The Searider’s ABS plastic hull is digitally-optimized to deliver outstanding performance and razor-sharp handling in compact areas like pools and small ponds. A convenient boat stand is also included for when the boat is in dry dock!
    Durable Running Hardware
    Including features usually found only on larger and more costly boats, the Searider has a flex-shaft prop drive and a hull that is optimized for most any operating environment or water condition.
    A reliable, interference-free radio system ensures that the Searider is always under your control at distances of up to 100M (300’).
    2.4GHz Pistol Grip Transmitter
    • RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
    • All Electronics are pre-installed
    • Fully Painted and Decorated
    • Rated for ponds or calm lakes appropriate for RC Boats
    • Bancroft Searider V4 360mm (14.2") Offshore Catamaran Racer - RTR
    • 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
    • Brushed, water-cooled motor drive system, pre-installed, with XT60 battery connector
    • 2S 7.4V 800mAh LiPo Battery
    • 2S Battery Charger
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :15 minutes
    Scale N/A
    Length 360mm / 14.2in
    Width 120mm / 4.7in
    Height 100mm / 3.9in
    Hull Material ABS
    Battery : 2S 7.4V 800mAh LiPo Battery
    Battery Quantity 1
    Battery Connector XT60
    Motor Brushed 390, water-cooled
    Motor Quantity 1
    Propeller Material Nylon Composite
    Contra-Rotating Propeller No
    ESC 15A Brushless, Water-cooled
    ESC Waterproof Splashproof
    ESC Quantity 1
    Radio Wheel
    Receiver Channels 2
