Mad Shark V2 Brushless 368mm (14.5") F1 Tunnel Hull from Bancroft - RTR - BNC1032-001
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
Thrilling to drive, the Bancroft Mad Shark V2 Brushless delivers the speed, control, and style needed to fly over the water like a full-size F1 tunnel in a convenient, Ready To Run (RTR) package. Open the box, charge the included battery with the provided charger, your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for balanced speed and maneuverability out of the box without any additional adjustment. The Bancroft Mad Shark V2 Brushless sports a realistic red racing scheme, accented by race-inspired decals, and easily distinguishable as the high-performance brushless version.
Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Mad Shark can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 3S battery, and battery charger.
Formula 1 Tunnel Hull Design The Mad Shark utilizes an F1 tunnel hull design, with CAD-designed sponsons and chine detail to deliver the feeling of “flying” on water! |
2.4GHz Pistol Grip Transmitter A reliable, interference-free radio system ensures that the Mad Shark is always under your control at distances of up to 100M (300’). |
Flex-Cable Drive System The Mad Shark features an efficient flex-cable driveshaft system to deliver maximum performance from the powerful brushless motor. Realism is enhanced by a faux outboard engine that serves as both the outdrive and rudder assembly. |
Vibrant Color Scheme The Mad Shark includes a bright and easy-to-see color and trim package that sets the brushless version apart and will make you the envy of other RC boaters and the local pond or lake! |
- RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
- All Electronics are pre-installed
- Fully Painted and Decorated
- Zero assembly required --Get underway in minutes!
- Rated for ponds or calm lakes appropriate for RC Boats
- Bancroft Mad Shark V2 Brushless 368mm (14.5") F1 Tunnel Hull - RTR
- 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
- Brushless, water-cooled motor drive system, pre-installed, with XT60 battery connector
- Steering servo, pre-installed
- 3S 11.1V 1300mAH LiPo Battery
- 3S Battery Charger
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH - we recommend Admiral AA NiMH 2600mAh rechargeable batteries
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :15 minutes
| Scale | N/A |
| Length | 368mm / 14.5in |
| Width | 172mm / 6.8in |
| Height | 130mm / 5.1in |
| Hull Material | ABS |
| Battery | 3S 11.1V 1300mAH LiPo Battery |
| Battery Quantity | 1 |
| Battery Connector | XT60 |
| Motor | Brushless, water-cooled |
| Motor Quantity | 1 |
| Propeller Material | Nylon Composite |
| Contra-Rotating Propeller | No |
| ESC | 30A Brushless, Water-cooled |
| ESC Waterproof | Yes |
| ESC Quantity | 1 |
| Radio | Wheel |
| Receiver Channels | 4 |
