Official Bancroft Rocket V2 550mm Offshore Deep V Racer Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Rocket V2 Brushless 550mm (21.7") Offshore Deep V Racer from Bancroft - RTR - BNC1034-001
Name:	bancroft-rocket-v2-550mm-21-7-offshore-deep-v-racer-rtr-motion-rc-29167555772601.jpg
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    The Bancroft Rocket V2 offers the speed, handling, and rough-water performance that only a streamlined offshore Deep Vee hull design can deliver in a convenient, Ready To Run (RTR) package. Open the box, charge the included battery with the provided charger, your own AA batteries into the included 2.4Ghz radio transmitter, and toss the boat into the water! All of the electronics are pre-installed, and the boat's running gear is setup for balanced speed and maneuverability out of the box without any additional adjustment. The Bancroft Rocket V2 Brushless sports a bright, neon trim scheme that accentuates its speed and shouts about the performance potential.
    Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Rocket V2 can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter, 3S battery, and battery charger.
    Water-Cooled Brushless Power
    Instantaneous acceleration and unsurpassed reliability are delivered by the included brushless water-cooled outrunner motor, coupled to an efficient 3mm flex-cable drive system.
    Extraordinary Running Hardware
    The heavy-duty aluminum rudder provides precise control and handling, while the included boat stand allows you to display or maintain the Rocket V2 when in dry dock.
    Self-Righting Function
    Run in confidence knowing that should your boat capsize from excessive chop or wind; the innovative self-righting function automatically returns your craft to upright and ready to return to shore.
    Aggressive Offshore Hull Design
    The sharp, powerful lines of the Rocket V2’s hull design provides razor-sharp handling, precise turning, and optimized top speed for a totally unique RC boat experience!
    • RTR (Ready to Run) with 2.4GHz radio, receiver, ESC, battery, and charger
    • All Electronics are pre-installed
    • Fully Painted and Decorated
    • Rated for ponds or calm lakes appropriate for RC Boats
    • Bancroft Rocket V2 550mm (21.7") Offshore Deep V Racer - RTR
    • 2.4Ghz Radio, Receiver, and Water-Cooled ESC, pre-installed
    • Brushless, water-cooled motor drive system, pre-installed, with XT60 battery connector
    • 3S 11.1V 2200mAh LiPo Battery
    • 3S Battery Charger
    AGE LEVEL : 14 and up
    SKILL LEVEL : intermediate
    BUILD TIME : 15 minutes
    Scale N/A
    Length 550mm / 21.7in
    Width 155mm / 6.1in
    Height 160mm / 6.3in
    Hull Material ABS
    Battery 3S 11.1V 2200mAH LiPo Battery
    Battery Quantity 1
    Battery Connector XT60
    Motor Brushless, water-cooled
    Motor Quantity 1
    Propeller Material Nylon Composite
    Contra-Rotating Propeller No
    ESC 30A Brushless, Water-cooled
    ESC Waterproof Yes
    ESC Quantity 1
    Radio Wheel
    Receiver Channels 4
  • serpentracer
    • Nov 2019
    • 112
    • Ohio
    is this thing worth buying? looks like most of the parts out back are plastic. and a little 30 amp esc.
