The RMS Titanic was a British passenger liner operated by the White Star Line that sank in the North Atlantic Ocean in the early morning hours of 15 April 1912, after striking an iceberg during her maiden voyage from Southampton to New York City. Of the estimated 2,224 passengers and crew aboard, more than 1,500 died, making the sinking one of modern history's deadliest peacetime commercial marine disasters. Built in Belfast, the Titanic was the largest ship afloat at the time she entered service and was the second of three Olympic-class ocean liners.
Bancroft’s Elite Series of liners presents our 1/150 scale Titanic! Display this impressively majestic 70-inch long museum piece on your mantle or astonish your RC boat club with this functional RTR historic piece. Hundreds of parts are already assembled, painted, and installed for you. Delivered Ready to Run (RTR), the vessel can be sailing within minutes of arrival, using the included 2.4Ghz radio transmitter, 7.4v 2S LiPo battery, and charger. Only four AA batteries and minimal assembly is required. Embark on your first voyage in minutes!
Positionable Fixtures Positionable hoisting cranes and lifeboats lend a sense of scale to this large RC vessel. |
Amazing Detail The Titanic's various decks are covered by large laser-cut and laser-etched decking, treated in a natural water-stabilized finish. |
Removeable Superstructure The primary superstructure is molded around one central base that can be removed with two hands. Simply lift the superstructure vertically to access the interior electronics bay to plug in the main battery and turn the system on. |
Extensive Rigging The Titanic boasts an extensive array of rigging that adds an exquisite level of scale realism to this functional museum piece. |
History In Miniature This 1/150 scale representation of the Titanic is in part faithfully represented by all the countless fine details that would have been found on the deck as she sailed to her fate. |
Multi-Material The Titanic boasts a multitude of materials from wood to fiberglass to metal. Brass, steel, aluminum, composite, and 3D printed parts form a concert of detail and realism. |
Easy To Sail The Bancroft 1/150 scale Titanic is as impressive in scale and scope as it is easy to operate on smooth waters. |
King Of The World! You can almost visualize Jack and Rose on the bow as imminent destiny awaits them. |
Durable Detailed Hull The Titanic's one piece hull is professionally molded from durable composite materials with marine-grade adhesives and durable reinforcements. |
Brass Photo Etched Details The Bancroft 1/150 scale Titanic astounds with over one hundred elements painstakingly assembled from brass Photo Etched (PE) details. |
Concealed Hatches Quickly access the internal battery bay and the steering servo by use of concealed, water-resistant hatches. |
Stunning Display The Bancroft Titanic could just as easily be displayed in a prestigious museum as it could be found sailing in your local RC marina. Modelers may also customize this large vessel with smoke and lighting effects. |
- RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
- 2.4Ghz radio system and all electronics installed
- Fully painted and detailed
- Zero assembly required — get underway in minutes
- Durable fiberglass one-piece molded hull and deck
- Genuine wood decking, laser-cut and laser-etched
- Hundreds of brass photo-etched (PE) parts and high detail parts
- Extensively detailed and hand finished
- Incredible scale detail representing more than 180 hours of hand craftsmanship
- Three motors with steel drive shafts
- Removable superstructure for easy access to the ship's interior
- Factory-installed rigging with simple disconnect design
- Rated for calm ponds and lakes appropriate for RC boats
- Bancroft RMS Titanic 1/150 Scale 1800mm (70.2") British Liner - RTR
- 2.4Ghz radio and receiver, factory-installed
- Triple motor drive system
- Three screws (propellers)
- Waterproofed hull and drive shafts
- Steering servo, installed and adjusted
- 2S 7.4V 2800mAh battery with XT60 connector
- 2S battery Charger
- Basic tabletop display stand
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH - we recommend the Admiral 2600mAh 1.2V NiMH AA Rechargeable Batteries (4 Pack)
Bancroft model boats are molded and hand finished using very intricate details and parts including metal, wood, plastic, and fiberglass. Because of their hand made nature, minor imperfections in the fiberglass, metalwork, or painting may exist. These potential imperfections will not affect the seaworthiness of the vessel or the overall scale boating experience. Bancroft scale RC boats are fragile so care should be taken when moving or transporting your model.
Some of the electronics in this Bancroft boat, including the Battery, ESC, Motor, and Receiver, are NOT intended to get wet; they are NOT water resistant. If any of these electronic components get wet and you attempt to operate your model, the water can cause an electrical short-circuit and void your warranty. In the rare instance that you get water inside your vessel, you should drain the water completely and allow all electronics to fully dry before attempting to operate your model. Product Specifications:
AGE LEVEL : 14 and up
SKILL LEVEL : Intermediate
BUILD TIME : 1 Hour
| Scale | 1/150 |
| Length | 1800mm / 70.2in |
| Width | 190mm / 7.4in |
| Height | 490mm / 19.1in |
| Hull Material | Fiberglass |
| Battery | 7.4V 2800mAh LiPo |
| Battery Quantity | 1 |
| Battery Connector | XT60 |
| Motor | 550 brushed motor |
| Motor Quantity | 3 |
| Propeller Material | Metal |
| Contra-Rotating Propeller | Yes |
| ESC | 120A |
| ESC Waterproof | Splash-Proof |
| ESC Quantity | 1 |
| Radio | Stick |
| Receiver Channels | 6 |
