Official Bancroft FDNY 343 1/35 Scale Fireboat Thread
  • jbaartz
    • Sep 2020
    • 488
    FDNY 343 1/35 Scale 1296mm (51") Fireboat - RTR by Bancroft - BNC1072-001
    The FDNY 343 Fireboat is a state-of-the-art vessel operated by the Fire Department of New York (FDNY), named in honor of the 343 firefighters who lost their lives during the September 11, 2001 terrorist attacks. Commissioned in 2010, this fireboat is not only a powerful firefighting tool but also a floating memorial to those heroes.
    Built by Eastern Shipbuilding Group, the FDNY 343 is one of the most advanced fireboats in the world. At 140 feet long and capable of pumping 50,000 gallons of water per minute, it is a critical asset for maritime emergencies, waterfront fires, and rescue operations along New York City’s waterways. It is equipped with high-tech radar, GPS navigation, thermal imaging, and communication systems, allowing it to operate efficiently in a wide range of emergency conditions.
    The vessel serves as the flagship of the FDNY Marine Division, replacing older fireboats while dramatically increasing firefighting and rescue capacities on the water. It is primarily based at Marine Company 1, located at Pier 53 on the Hudson River.
    Beyond its technical capabilities, the FDNY 343 also functions as a symbol of resilience and remembrance. The name pays tribute not only to the fallen of 9/11 but also to the enduring spirit of the FDNY. Its presence on the water serves as a reminder of the bravery, sacrifice, and service of New York’s firefighters, and it plays a ceremonial role during memorial events, parades, and public safety demonstrations throughout the city.
    Bancroft’s exquisite, museum-quality replica of this remarkable vessel features an impressive combination of breathtaking, realistic detail and operational features. This 1296mm (51”) long model includes an operational bow thruster system that allows the ship to virtually rotate around its axis which delivers unsurpassed maneuverability, while the 11 operational water cannons provide the FDNY 343 with an ability to impress the most discerning modelers or pondside spectators.
    Powered by four inboard 550-class brushed motors and steered by four individual rudders, this fully assembled, ready-to-run model delivers an impressive presence both on the water and on display. A supplied 3S LiPo battery operates the functional bow thruster and water cannons, while a separate 2S LiPo battery provides propulsion power. An included AC charger handles charging for both batteries (one at a time). The main superstructure is easily removed in one piece and secured to the hull with high-strength magnets for convenient access to plumbing and electronics located inside the hull.
    Combine this impressively realistic, operational replica from Bancroft with Motion RC’s industry-leading technical and customer service support for an unsurpassed modeling experience!
    Four Motor/Four Screw Propulsion
    Driven by four high-torque motors and matched to four propellers, the system delivers powerful, coordinated propulsion for precision performance.
    Hand Crafted, Not Mass Produced
    Bancroft ship models are created by skilled artisans that devote hundreds of hours to the fabrication of these museum-quality replicas.
    Precision Plumbing
    The FDNY 343 contains eleven operational fixed firefighting turrets fed by a high-volume pump and controlled by a dedicated ESC and battery pack. Simply push up on the right transmitter stick to start the water flowing!
    Supreme Scale Realism
    The Bancroft FDNY 343 1/35 Scale Fireboat delivers a remarkable combination of true-to-life details, operating features, and practical performance. Built for ease of use with minimal maintenance, this vessel is equally suited for display on its included stand or navigating your favorite lake or pond with impressive performance and realism.
    Functional Bow Thruster
    The operational bow thruster system fabricated within the bow provides unmatched maneuverability for operating in tight confines. Simply push right or left on the throttle stick to activate this handy performance feature!
    Photo-Etched Detail Parts
    Some of the Photo-Etched (PE) parts and antennae are thinner than a pin, and some details are only visible under a magnifying glass! The durable PE railings can be gently bent back to shape like a paper clip if minor bends occur during normal transport or handling.
    • RTR (Ready to Run) with 2.4Ghz radio, ESC (2), receiver, batteries (2), and AC charger
    • Factory-installed water cannon system with eleven individual fixed turrets
    • Durable fiberglass one-piece molded hull
    • Factory-installed bow thruster system
    • Zero assembly required — get underway in minutes
    • 2.4GHz radio system and all electronics installed
    • Fully painted and detailed
    • Ultra-realistic exhaust stacks
    • Hundreds of brass photo-etched (PE) parts and highly detailed parts
    • Extensively detailed and hand-finished
    • Incredible scale detail representing more than 210 hours of hand craftsmanship
    • Steel driveshafts
    • Removable superstructure for easy access to the ship's interior
    • Rated for calm ponds and lakes appropriate for RC boats
    • Bancroft FDNY 343 1/35 Scale 1296mm (51") Fireboat RTR
    • 2.4Ghz radio and receiver, factory-installed
    • Powerful 550-class brushed marine motor drive system
    • Realistic bow thruster and water cannon system
    • Waterproofed hull and drive shafts
    • Steering servo, installed and adjusted
    • 2S 7.4V 2800mAh battery with XT60 connector
    • 3S 11.2V 1800mAh battery with XT60 connector
    • AC automatic battery charger
    • Instruction manual
    • Tabletop display stand
    Bancroft model boats are molded and hand finished using very intricate details and parts including metal, wood, plastic, and fiberglass. Because of their hand made nature, minor imperfections in the fiberglass, metalwork, or painting may exist. These potential imperfections will not affect the seaworthiness of the vessel or the overall scale boating experience. Bancroft scale RC boats are fragile so care should be taken when moving or transporting your model.
    Some of the electronics in this Bancroft boat, including the Battery, ESC, Motor, and Receiver, are NOT intended to get wet; they are NOT water resistant. If any of these electronic components get wet and you attempt to operate your model, the water can cause an electrical short-circuit and void your warranty. In the rare instance that you get water inside your vessel, you should drain the water completely and allow all electronics to fully dry before attempting to operate your model. Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : intermediate
    BUILD TIME : 1 hour
    Scale 1/35
    Length 1296mm / 51in
    Width 335mm / 13.2in
    Height 495mm / 19.5in
    Hull Material Fiberglass
    Battery 7.4V 2800mAh LiPo, 11.1V 1800mAh LiPo (included)
    Battery Quantity 2
    Battery Connector XT60
    Motor 550 brushed x 5 (4 x propulsion, 1 x bow thruster), 520 brushed x 1 (water cannons)
    Motor Quantity 6
    Propeller Material Metal
    Contra-Rotating Propeller No
    ESC 120A x 1, 30A x 1
    ESC Waterproof Splash-Proof
    ESC Quantity 2
    Radio 2.4GHz stick
    Receiver Channels 6
