Official Bancroft 1/200 Scale Queen Mary 2 Passenger Ship Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The RMS Queen Mary 2 is the world’s last true ocean liner, purpose-built for regular transatlantic service and engineered to standards far beyond those of conventional cruise ships. Entering service in 2004 for Cunard Line, she was designed specifically to withstand the harsh conditions of the North Atlantic, continuing a lineage of famous Cunard liners that dates back to the 19th century.
    Measuring 1,132 feet (345 meters) in length with a gross tonnage of approximately 149,000, Queen Mary 2 was the largest passenger ship ever constructed at the time of her launch. Her hull features increased structural strength, a deeper draft, and a reinforced bow optimized for sustained high-speed operation in open ocean. Propulsion is provided by a combined diesel-electric and gas turbine (CODAG) system driving four azimuthing podded propulsors, delivering a service speed of around 26 knots.
    Unlike modern cruise ships, Queen Mary 2 retains classic ocean liner proportions, including a longer hull form and a more vertical bow profile. Today, she remains the flagship of Cunard’s fleet and the only vessel still offering scheduled transatlantic crossings between Southampton and New York, preserving a historic mode of ocean travel through modern engineering.
    Bancroft’s stunning 1/200 scale model of this majestic vessel is not only perfect for display, the realistic brushless-powered propulsors and bow thruster system delivers impressive performance and maneuverability. When combined with her multitude of scale details, the Bancroft Queen Mary 2 is a model that delivers a magnificent presence on any suitable pond or lake, while Motion RC’s industry-leading product support and customer service ensures a modeling experience like no other.
    Crafted By Hand, Not Machines
    Bancroft ship models are created by skilled artisans that devote hundreds of hours to the fabrication of these museum-quality replicas.
    Stunning Scale Realism
    Every detail of the 1:1 scale Cunard ocean Liner has been painstakingly recreated in Bancroft’s 1/200 scale version. Foredeck sports courts, swimming pools, hot tubs, deck balconies and other details allow for pleasurable scale cruising.
    Brushless Propulsors
    The propulsion and steering system of the QM2 is faithfully replicated using rotating pods with brushless motors for precise control. When combined with the bow thruster system, the QM2 can maneuver sideways into the tightest birth or pier!
    Take A Dip
    The aft deck swimming pool provides passenger comfort, while the hand-fabricated metal ladders and railings provide an exquisite level of scale realism.
    Realistic Bow
    The bulbous bow shape of the QM2 reduces drag and improves speed, efficiency, and passenger comfort. The Bancroft QM2 faithfully replicates this feature found on the real ship.
    Man the Lifeboats!
    The complete array of safety equipment found on the 1:1 scale QM2 is replicated on the Bancroft 1/200 scale version.
    • RTR (Ready to Run) with 2.4Ghz radio, receiver, batteries, and charger
    • Zero assembly required — get underway in minutes
    • 2.4Ghz radio system and all electronics installed
    • Realistic power pods (4) powered by brushless motors
    • Operational bow thruster system
    • Fully painted and detailed
    • Durable fiberglass one-piece molded hull
    • Hundreds of brass photo-etched (PE) parts and high detail parts
    • Extensively detailed and hand-finished
    • Incredible scale detail representing more than 200 hours of hand craftsmanship
    • Removable superstructure for easy access to the ship's interior
    • Rated for calm ponds and lakes appropriate for RC boats
    • Bancroft 1/200 Scale Queen Mary 2 1725mm (67.9") Passenger Ship - RTR
    • 2.4Ghz radio and receiver, factory-installed
    • Powerful brushless propulsors
    • Waterproofed hull
    • Steering servo, installed and adjusted
    • Two 2S 7.4V 2800mAh batteries with XT60 connector
    • AC automatic battery charger
    • Instruction manual
    • Tabletop display stand
    Bancroft model boats are molded and hand finished using very intricate details and parts including metal, wood, plastic, and fiberglass. Because of their hand made nature, minor imperfections in the fiberglass, metalwork, or painting may exist. These potential imperfections will not affect the seaworthiness of the vessel or the overall scale boating experience. Bancroft scale RC boats are fragile so care should be taken when moving or transporting your model.
    Some of the electronics in this Bancroft boat, including the Battery, ESC, Motor, and Receiver, are NOT intended to get wet; they are NOT water resistant. If any of these electronic components get wet and you attempt to operate your model, the water can cause an electrical short-circuit and void your warranty. In the rare instance that you get water inside your vessel, you should drain the water completely and allow all electronics to fully dry before attempting to operate your model. Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 1 Hour
    Scale 1/200
    Length 1725mm / 67.9in
    Width 205mm / 8.1in
    Height 360mm / 14.2in
    Hull Material Fiberglass
    Battery 7.4V 2800mAh LiPo
    Battery Quantity 2
    Battery Connector XT60
    Motor Brushless (propulsion), brushed (bow thruster)
    Motor Quantity 4 brushless, 1 brushed
    Propeller Material Metal
    Contra-Rotating Propeller No
    ESC 4 brushless, 1 brushed
    ESC Waterproof No
    ESC Quantity 5
    Radio 2.4GHz stick 4-channel
    Receiver Channels 4
