Focus II 995mm (39.2") Sailboat from Bancroft - RTR - BNC1047-001
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
Standing at impressive overall height of 2046mm (80.5”), the Bancroft Focus II is the perfect 1M Class sailboat capable of operating in stronger breezes and larger bodies of water. Quickly and conveniently disassembled, the impressive Focus II can be easily transported in most cars. The Focus II arrives carefully packed and semi-assembled, with masting and final rigging left to the buyer prior to being ready to sail. Simply install 4 AA alkaline batteries in the boat, 4 AA alkaline batteries in the transmitter, and the Focus II can be ready to enjoy a gentle breeze on a summer evening or the excitement of skippering an America’s Cup yacht.
Display this yacht on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), your Focus II can be sailing shortly after opening the box, using the included 2.4Ghz stick radio transmitter.
Features:
AGE LEVEL : 14 and up
SKILL LEVEL : intermediate
BUILD TIME : 30-60 minutes
Heavy-Duty Sail Winch and Rudder Servo The Focus II features a heavy-duty drum-style sail winch to tack the mainsail and a compact servo for rudder control. The layout of the radio box is clean and components easily accessed and adjusted. |
Impressive Size Standing almost 7’ tall out of the water, the Focus II makes a big impression on its captains and competitors alike. There are few RC experiences that can match the thrills of accurately controlling a large, majestic sailing yacht! |
Precision Rigging and Control The attention to quality is impressively expressed by the waterproof Focus II rudder control and on/off switch linkage. |
Quality Fittings and Hardware The Focus II uses carbon fiber tubing for masts and booms, combining with fiber-reinforced composite fittings to create an adjustable yet durable 1M sailing yacht. |
- RTR (Ready to Run) with 2.4GHz radio, receiver, sail, and rudder servos
All Electronics are pre-installed - Fully Painted and Decorated
- Simple assembly required --Get underway after final assembly and rigging!
- Rated for ponds or lakes appropriate for larger RC Boats
- Bancroft Focus II 995mm (39.2") Sailboat - RTR
- 2.4Ghz Radio, Receiver, sail, and rudder servo, pre-installed
- Innovative 2.4GHz stick transmitter for comfortable control
- Eight (8) AA-sized 1.5V dry cell batteries (Alkaline or Rechargeable NiMH) - we recommend Admiral AA NiMH 2600mAh rechargeable batteries
| Scale | N/A |
| Length | 995mm / 39.2in |
| Width | 170mm / 6.7in |
| Height | Overall-2046mm / 80.5in. Mast-1578mm / 62.1in. |
| Hull Material | ABS |
| Battery | AA Alkaline x 4 (not included) |
| Battery Quantity | 4 |
| Battery Connector | Radio |
| Motor | N/A |
| Motor Quantity | N/A |
| Propeller Material | N/A |
| Contra-Rotating Propeller | N/A |
| ESC | N/A |
| ESC Waterproof | N/A |
| ESC Quantity | N/A |
| Radio | Stick |
| Receiver Channels | 2 |
