Official Chasing M2 Professional Submersible ROV with 4K Video Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    M2 Professional Submersible ROV with 4K Video - RTR from Chasing Innovations - CHS40-10-202-00013
    Version Info: This ROV is delivered as “RTR” and requires a smartphone and downloading of a free app for successful operation.
    Explore the underwater wonders of rivers, lakes, or oceans with the M2 Professional Submersible ROV, now available through Motion RC. The M2 is a professional quality, feature-rich ROV intended for sophisticated users or commercial/industrial applications like underwater hull or dock inspections, search and rescue, or aquaculture. The eight vectored thrusters on the M2 hull allow sophisticated underwater movements in any direction. Surprisingly compact, the Pro weighs only 4.5Kg (9.9 lbs.) and is controlled through an included, tethered transmitter supplemented by your smartphone or tablet. Real-time water temperature, depth, and other parameters provide mission support, while a rechargeable battery pack delivers up to an impressive two hours of operation per charge at depths up to 100M (330’).
    A 1/2.3 Sony CMOS camera with EIS and anti-shake video stabilization, a 4K f/1.8 lens, and 4000 lumen dimmable LED lights combine to ensure that every detail of your underwater exploration is crystal-clear and easily documented. Support accessories such as a grabber claw arm or sports cameras (not included) deliver more ways to work or have fun! The patented motor/prop system greatly reduces the chances of problems caused by debris, sand, or rocks, allowing the M2 to confidently tackle complicated underwater environments. With a maximum speed of 3 knots and a 152o field of view the Chasing M2 is a versatile, durable workhorse or exploration machine!
    Combine the compact and portable, go-anywhere fun of the Chasing M2 Professional Submersible ROV with Motion RC’s industry-leading customer service and product support for an unbeatable package!
    Get out and explore
    The M2 is a versatile submersible that will allow you to unleash your inner Jacques Cousteau. Stunningly clear photography and videography will be yours to enjoy!
    4K with EIS image stabilization with f/1.8 Aperture
    The M2 delivers high-definition 12 megapixel still images and dramatic 4K or 1080p videos thanks to its Sony CMOS camera.
    Compact and Convenient
    The M2 is surprisingly compact and easily transportable to some of the most stunning environments. Convenient, watertight access to the included 64G Micro SD card means you can download your media anytime, anywhere.
    Direct Connection
    The controller and smartphone/tablet are directly connected via tether cable, eliminating the chance for WiFi interference or signal loss while enhancing image and data stability.
    • Conveniently-sized, compact design with aluminum alloy outer hull
    • Waterproof to 100M (330’)
    • Patented propulsion system
    • 64G Micro SD memory card
    • Built in battery pack and included AC charger
    • Complete package, ready for use-just add smartphone or tablet
    • Operates over two hours per charge
    • Customized visual effects with 19 available image filters
    • User-friendly app allows direct share or live stream to Social Media
    • Sony CMOS camera with EIS stabilization
    • Optional arms and mounts available for varied work tasks
    • 4K UHD video with f/1.8 lens
    • 2x 2000 Lumens dimmable front-mounted LED lamps
    • Chasing M2 Professional Submersible ROV with 4K Video
    • 100M tether cable
    • Remote controller
    • AC Charger
    • Storage case
    • GoPro™ mounting base
    • Spare O-Rings
    • Absorbent towel
    Requires:
    • Smartphone or Tablet
    • Download of free APP
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 5 Minutes
    Length 380mm / 15in
    Width 267mm / 10.5in
    Height 165mm / 6.5in
    Weight 4500g / 158.7oz
    Max Depth 100 meters
    Max Speed 1.5 m/s (3 Knots)
    Runtime 2-4 hours
    Battery Life Cycle >300 cycles
    Max WiFi Distance N/A
    Operating Temperature -10°C-45°C / 14°F-113°F
    Power 2.9A / 25.2V
    Charging Time 2 hours
    LED Brightness 2x 2000 lumens
    LED Color Temperature 5000K-5500K
    LED CRI 85
    LED Dimming Three gears
    CMOS 1/2.3 (SONY)
    Lens F/1.8
    Focus 1m
    ISO Range 100-6400
    FOV 152°
    Max Resolution 12 mega pixel
    Image Format JPEG / DNG
    Video
    • 4K / 30fps
    • 1080p / 30fps, slow motion (120fps)
    • 720p / 30fps, slow motion (240fps)
    Video Stream 60M
    Video Format MP4
    SD Card 64GB
    IMU 3 axis gyro/accelerometer/compass
    Depth Sensor ≤±0.25m
    Temperature Sensor ≤±2°C / 3.6°F
  • Gilatrout
    RC Pilot Addict
    • 806
    • Albuquerque NM
    This is seriously cool. I would have killed to have something like this when I lived in coastal MA. Occasionally a ball of herring would get trapped by predators,. probably striped bass, at the head of a little cove across from my house. I'd watch the birds dive in and see the sea surface roil. How freaking cool would it be to be a fly, I mean submersible, watching it from below?
    We would also go snorkeling in a different, starfish, lobsters, crabs, small fish including a small shark called a dogfish were common...again How freaking cool would it be to send in an rov?
    Now that I'm in NM, all I have are some murky lakes. Not quite the same. But this is so freaking cool Motion.
    I want one. Now I just need.to justify one in a desert...
