Official Chasing Dory Compact Submersible ROV with HD Video Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Dory Compact Submersible ROV with HD Video - RTR from Chasing Innovations - CHS40-10-300-0001
    Version Info: This ROV is delivered as “RTR” and requires a smartphone and downloading of a free app for successful operation.
    Explore the underwater wonders of rivers, lakes, or oceans with the Dory Compact Submersible ROV, now available from Motion RC. This compact submersible is immensely portable, weighing only 1.1Kg (2.4 lbs.) and controlled through a tethered, GPS-enabled WiFi buoy using your smartphone or tablet. The Dory’s internal battery delivers up to an hour of operation on a single charge at depths up to 15M (45 feet), and an adjustable 45-degree tilt-lock function assists with capturing that perfect image or video.
    The 1080p f/1.6 lens camera is tailored for underwater exploration, while the “two-player mode” function allows one person to control the ROV while the other operates the camera. Never before has underwater photography and exploration been easier or more affordable!
    Combine the compact and portable, go-anywhere fun of the Chasing Dory Compact Submersible ROV with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    ±45° Tilt-Lock Mode
    Orient and hold the Dory down or up to capture incredible angles for the best underwater images.
    1080p with f/1.6 Aperture
    The HD Camera pushes the boundaries of what’s possible with wide aperture settings for optimal low-light performance. The app offers 19 image filters to enhance any photo taken with Dory, and images or video can be shared directly to Social Media or even live streamed directly through Facebook.
    Dive Deep
    Stay just below the waves or dive deep up to 15M, the choice is yours!
    Intuitive Controls
    Dory’s free app turns your smartphone or tablet into the controller, equipped with virtual joysticks and controls for effortless and precise operation.
    • Conveniently-sized, compact, lightweight design
    • Waterproof to 15M (49’)
    • Complete package, ready for use-just add smartphone or tablet
    • Operates up to one hour per charge
    • ±45° adjustable tilt-lock mode
    • Adjustable depth hold
    • GPS-enabled WiFi buoy with 15M tether cable provides real-time location data
    • Customized visual effects with 19 available image filters
    • User-friendly app allows direct share or live stream to Social Media
    • 1080p video with f/1.6 lens
    • Includes convenient travel case for storage
    • 2x 250 Lumens front-mounted LED lamps
    • Chasing Dory Compact Submersible ROV with HD Video
    • GPS-enabled WiFi Buoy
    • 15M Tether Cable
    • AC Charger
    • Protective Travel Case
    Requires:
    • Smartphone or Tablet
    • Download of free APP
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 5 Minutes
    Length
    • Drone: 247mm / 19.7in
    • Buoy:130mm / 6in
    Width
    • Drone: 188mm / 7.4in
    • Buoy:130mm / 6in
    Height
    • Drone: 92mm / 3.6in
    • Buoy:88mm / 3.5in
    Weight
    • Drone: 1100g / 38.8oz
    • Buoy: 160g / 5.6oz
    Max Depth 15 meters
    Max Speed 0.25 m/s (1.5 Knots)
    Runtime 1 hour
    Battery Life Cycle >300 cycles
    Max WiFi Distance 15m (Buoy)
    Operating Temperature -10°C-60°C / 14°F-140°F
    Power 1.8A / 12.6V
    Charging Time 2 hours
    LED Brightness 2x 250 lumens
    LED Color Temperature 4000K-5000K
    LED CRI 80
    LED Dimming N/A
    CMOS 1/2.9in
    Lens F/1.6
    Focus 4mm
    ISO Range 100-3200
    FOV 100°
    Max Resolution 2M (1920x1080)
    Image Format JPEG
    Video FHD: 1920x1080 / 30fps
    Video Stream 4M
    Video Format MP4
    SD Card 16GB (buoy internal storage)
    IMU 3 axis gyro/accelerometer/compass
    Depth Sensor ≤±0.5m
    Temperature Sensor ≤±2°C / 3.6°F
    Got the first test dive out of the way tonight. Just a little swimming pool test, but the lights and everything worked perfectly
