Motion RC is proud to represent the Team Corally brand of high-quality surface RC vehicles, including this stunning 1/8 scale Python XP 4WD Buggy. Delivered Ready to Run ("RTR") with all onboard electronics pre-installed, simply add your 2S-6S LiPo battery with XT90 connector and your preferred charger and this beast is ready for exciting off-road adventures!
If you need crazy, indecent speed, you have to take a look at the Python buggy in action! With LiPo up to 6S and a Kv 2050 engine, you will be able to dominate a crowd of competitors thanks to the great super buggy Python! It is perfect for jumps in the dust or in skateparks, wherever you want to achieve supremacy in the air as by incredible speeds!
With an ultra-durable all-metal 4-wheel drive, completely independent suspensions, a racing chassis and racing aerodynamics, this is the ultimate truck for driving and for those looking for the biggest jumps and frightening speeds!
Visit the Official Team Corally Python 1/8 Scale Buggy RTR Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
Self-Centering Competition-Grade Roll Bar System The Team Corally Python features a self-centering competition-grade anti-roll bar system factory-tuned to perfection. |
| Aluminum Reinforced Suspension Precision machined CNC aluminum shock towers and an aluminum reinforced suspension provide exceptional off-road durability. |
4mm Hard Chrome Plated Spring Steel Turnbuckles Corrosion resistant spring steel turnbuckles strike the perfect balance between strength, durability, flexibility, and adjustability. |
| Pre-Installed Electronics The Python arrives with pre-installed electronics including the radio transmitter, receiver, 2050kV brushless motor, splashproof 150A ESC, and steering servo. Simply add your AA batteries for the radio and your main LiPo drive battery into the vehicle. |
16mm Big Bore Aluminum Shocks Adjustable big bore 16mm aluminum body shocks deliver positive traction and a confident ride over any bump and obstacle. Tune the stiffness to your preferences in seconds by rotating the threaded adjustment nut up or down. |
| All Metal Drivetrain with Oversized Bearings Survive punishing bashing sessions with the Shogun's durable all-metal drivetrain supported on oversized bearings. |
Heavy Duty Aluminum Sliding Motor Mount Dial in a perfect gear mesh with the durable aluminum adjustable sliding motor mount. The mount's sliding design also facilitates easy motor removal to service the pinion and clean debris after especially rough driving. |
| RTR - "Ready To Run" With the majority of electronics pre-installed at the factory, simply add your chosen 2S-6S LiPo battery and charger (not included) to begin dominating the nearest RC track or trail! |
CNC-Machined Steel Geared Differentials The CNC-machined steel geared differentials offer rock-solid performance and durability each and every time. |
| 1/8 Scale The 1/8 scale size is a perfect blend of presence and ease of transport. |
- Pre-assembled racing buggy with electronics, bodywork and tires installed
- Team Corally TOROX 185 brushless controller for LiPo 3 to 6S with LiPo protection (programmable)
- Team Corally Kuron 2050 kV 4 pole brushless motor for 2 to 6S
- Varioprop® CR-7220-MG digital high-torque servo (20 kg.cm) and metal gears
- Aluminum servo lifter
- Ergonomic Varioprop® S2R transmitter with 2.4GHz technology without interference
- Separate splash and dirt proof electronic unit with transponder support
- Adjustable battery holder for most common LiPo batteries
- Complete set of sealed rubber flange bearings
- All the transmission bearings are in 8 x 16 x 5 mm format
- Motor pinion and crown in treated steel
- Three metal differentials, waterproof and silicone bath with quick access
- Quick and easy access to differentials
- Two-part aluminum motor support with composite pinion cover
- Fully metal transmission
- CVD front gimbals in metal
- 17mm Aluminum wheel hexes
- 16mm Big Bore threaded aluminum hydraulic shock absorbers
- Spring locking system
- Shock absorber supports in milled aluminum, 5 mm at the rear, 4 mm at the front
- Independent front suspensions on ball joints
- Independent rear double wishbone suspensions
- Aluminum suspension supports with composite cover
- Complete set of machined steel rods with 7 mm hexagons
- Individually adjustable chassis and steering geometries
- Team Corally RSP anti-roll bar system at the front and rear
- Aluminum chassis plate
- Chassis side protections with integrated body protection
- Front bumper with chassis protection
- High-deviation fin and reinforced support
- High-speed low-profile tires pre-glued on 5-spoke black nylon rims
- Robust and printed polycarbonate body
- Large choice of optional parts available
- Speed of more than 110 km / h (> 70 mph) possible
- Team Corally Python XP 4WD EP 1/8 Scale Buggy - RTR
- Ergonomic Varioprop® S2R transmitter, with interference-free 2.4GHz technology
- Team Corally Kuron 2050kV 4-pole brushless motor 2-6S
- Team Corally TOROX 185 150A ESC 2-6S with LiPo protection (programmable)
- Varioprop® CR-7220-MG High Torque Digital Servo, Metal Gear, 20 Kg Torque
- Adjustable battery holder for all common LiPo batteries
- Full set of ball bearings, rubber sealed
- 6x AA batteries for 2.4GHz radio transmitter - we recommend Admiral AA NiMH 2600mAh Rechargeable Batteries (Pack of 6)
- 2S to 6S (7.4V to 22.2V) LiPo Battery with XT90 connector
- 2 Cell to 6 Cell compatible battery charger - select a minimum 2 cell (2S) charger from our Charger Collection
