1/28 Scale 4WD Rally Car - RTR from XK Innovations - WLT-K989-001
The XK Innovations K989-001 1/28 scale 4WD Rally Car features a capable and durable all-wheel-drive chassis layout topped with a rally car body design that delivers dramatic action and impressive top speeds for a vehicle with a 93mm (3.8”) wheelbase! In addition to a durable aluminum chassis and top plate with convenient access to electronics, the independent suspension with individual coil-over dampers and all-surface tires are perfect for high-speed runs or rally stages. Similar in size to other series of Mini-class RTRs. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
Independent Suspension RC fans will notice the traditional chassis layout first pioneered by 1/10-scale electric touring cars! The model also features coil-over dampers for optimized handling and performance, while being similarly sized to other cars in this category. |
Rally-Tuned Chassis, Suspension, and Tires Ideal for tarmac or terrain, this model comes ready to tackle most terrain-from kitchen floor to wilderness dirt! From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK 1/28 Scale 4WD Rally Car is truly complete. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action! |
- Functions: forward, backward, turn left, turn right
- Interference-free 2.4GHz radio technology
- Intended for smooth surfaces
- Coil-over dampers
- Aluminum plate-style chassis and upper deck for supreme durability
- Geared differentials
- 4WD system provides plenty of power with impressive acceleration
- XK 1/28 Scale 4WD Rally Car – RTR
- 2.4GHz Transmitter
- 2S 7.4V 400mAh Lithium battery with JST-connector
- USB-Powered Battery Charger
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL :10 and up
SKILL LEVEL :beginner
BUILD TIME :none
| Model Scale | 1/28 |
| Length | 165mm / 6.5in |
| Width | 80mm / 3.1in |
| Height | 58mm / 2.2in |
| Weight (No Battery) | N/A |
| Wheelbase | 98mm / 3.8in |
| Ground Clearance | 3.6mm / 0.15in |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Aluminum Double-Deck |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 27mm (1.05”) x 8mm (.31”) |
| Wheel Hex Size | N/A |
| Tire Tread | Rally multi-surface |
| Bushing Material | N/A |
| Suspension | 4-wheel independent |
| Shock Type | Coil-over |
| Transmission | F/R Differentials, Center shaft |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Composite Bevel Gear |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | Yes, splash-proof |
| Motor | 130 Brushed |
| Battery | 2S LiPo with JST-connector (included) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | Digital, 3-wire |
| Radio | 2 Channel 2.4GHz (included) |
| Lights | No |
| Sound | No |
| Water Resistant | No |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | Indoors/Outdoors |
