Official XK Innovations 1/28 Scale 4WD Rally Car RTR Thread
  • Official XK Innovations 1/28 Scale 4WD Rally Car RTR Thread
    1/28 Scale 4WD Rally Car - RTR from XK Innovations - WLT-K989-001
    The XK Innovations K989-001 1/28 scale 4WD Rally Car features a capable and durable all-wheel-drive chassis layout topped with a rally car body design that delivers dramatic action and impressive top speeds for a vehicle with a 93mm (3.8”) wheelbase! In addition to a durable aluminum chassis and top plate with convenient access to electronics, the independent suspension with individual coil-over dampers and all-surface tires are perfect for high-speed runs or rally stages. Similar in size to other series of Mini-class RTRs. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Independent Suspension
    RC fans will notice the traditional chassis layout first pioneered by 1/10-scale electric touring cars! The model also features coil-over dampers for optimized handling and performance, while being similarly sized to other cars in this category.
    Rally-Tuned Chassis, Suspension, and Tires
    Ideal for tarmac or terrain, this model comes ready to tackle most terrain-from kitchen floor to wilderness dirt! From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK 1/28 Scale 4WD Rally Car is truly complete. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action!
    Features:
    • Functions: forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Intended for smooth surfaces
    • Coil-over dampers
    • Aluminum plate-style chassis and upper deck for supreme durability
    • Geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    Includes:
    • XK 1/28 Scale 4WD Rally Car – RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 400mAh Lithium battery with JST-connector
    • USB-Powered Battery Charger
    AGE LEVEL :10 and up
    SKILL LEVEL :beginner
    BUILD TIME :none
    Model Scale 1/28
    Length 165mm / 6.5in
    Width 80mm / 3.1in
    Height 58mm / 2.2in
    Weight (No Battery) N/A
    Wheelbase 98mm / 3.8in
    Ground Clearance 3.6mm / 0.15in
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum Double-Deck
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 27mm (1.05”) x 8mm (.31”)
    Wheel Hex Size N/A
    Tire Tread Rally multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Coil-over
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Composite Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Yes, splash-proof
    Motor 130 Brushed
    Battery 2S LiPo with JST-connector (included)
    Servos Digital, 3-wire
    Radio 2 Channel 2.4GHz (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
    An immersion blender splatter, also known as a stick blender, mini blender, hand blender, or wand blender, is a kitchen blade grinder used to blend ingredients or puree food in the container in which they are being prepared.
