Official XK Innovations Rock Buggy 1/10 Scale 4WD Crawler Thread
  • Official XK Innovations Rock Buggy 1/10 Scale 4WD Crawler Thread
    Rock Buggy 1/10 Scale 4WD Crawler - RTR from XK Innovations - WLT-104310-001
    The XK Innovations 104310 Rock Buggy 1/10 Scale 4WD Crawler features realistic scale appearance details that looks great on the dirt or trail. This crawler chassis features solid axles, link-style suspension, and realistic spring dampers that deliver a fun driving experience. The twin-280 motors, one on each axle, provide the vehicle with power while eliminating maintenance-intensive driveline components, while the built in, rechargeable battery pack delivers run times of 20-30 minutes.
    Even with all of those features, you may like the XK Rock Buggy’s realistic appearance so much that it never leaves the display shelf! Regardless of its ultimate parking spot, this vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Dual-Motor Performance
    The XK Rock Buggy features a traditional crawler chassis design with MOA (motor-on-axle) convenience and reliability. From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK Rock Buggy 1/10 Scale 4WD Crawler is truly complete.
    Reliable 2.4GHz Radio System
    The included, comfortable transmitter is full-featured and comfortable to use for hours of RC fun. Simply add 4 AA alkaline batteries (not included) and you’re ready for supreme driving action!
    • Functions: Fully proportional forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Perfect for youngsters to learn to drive RC!
    • Coil-over spring dampers
    • Dual-motor 4WD system
    • XK Rock Buggy 1/10 Scale 4WD Crawler – RTR
    • 2.4GHz Transmitter
    • 7.4v 1200mAh LiPo battery
    • USB-Powered LiPo Battery Charger
    • Screwdriver
    • Instructions
    AGE LEVEL : 7 Years and Up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 472mm / 18.4in
    Width 268mm / 10.5in
    Height 227mm / 8.8in
    Weight (No Battery) 1740g / 62.1oz
    Wheelbase N/A
    Ground Clearance 47mm / 1.8in max
    Body Polycarbonate, factory painted and decorated
    Chassis Nylon composite
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Coil Over Dampers
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential None
    Ball Bearings No
    Brakes Electronic
    Electronic Speed Control Yes
    Motor 280 Brushed x 2
    Battery 2S LiPo battery (included)
    Servos N/A
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time None
