Version Info: This car is delivered as "RTR", however does require 4x AAA batteries for the transmitter and 4x AAA batteries for the chassis, purchased separately (see Requires below for details).
To bring its dynamic performance to even more drivers, the MINI-Z AWD is now available in a Readyset. The MA-020 chassis features VCS (variable camber suspension) on the front that optimizes camber change with suspension stroke and a specially designed circuit board. The chassis design allows space for installing the optional MZW431 gyro unit. The gyro can be adjusted by turning a small volume adjuster on the chassis to reflect the amount of steering correction in response to changes in chassis posture, allowing beginners through to experts to drive to their full potential.
Fully kitted out with precision ball bearings, the high drive efficiency of the MA-020 chassis is complimented in the Readyset by the unique scale body and 2.4GHz Syncro KT-531P R/C system that requires no frequency band setting; all at a great value price. Simply install the batteries to enjoy the thrill of drift driving with the included set of drift tires. The chassis is compatible with nearly all ASC MINI-Z bodies (additional parts may be required for some body styles). The MINI-Z AWD promises a unique world of dramatic racing action for you to experience and enjoy and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
VCS Front Suspension Features VCS front suspension that optimizes camber change with suspension stroke. Replacement of front suspension coil springs is easy with no tools required. |
Gyro Mounting Space* AWD version is designed with special mounting space for gyro (MZW431/sold separately*) and gyro adjustment volume control. |
Strut-Type Rear Suspension Equipped with strut-type rear suspension. |
Drift Tires Equipped with drift tires and Full 14 ball bearing set as standard. |
- MINI-Z AWD Readyset based on MA-020 chassis
- Special circuit board updated with optimized steering control program
- Chassis features gyro sensitivity adjustment function
- Drift tires are installed as standard
- Readyset requires only batteries to be ready for action!
- Features 2.4GHz Syncro KT-531P transmitter that requires no setup of frequency bands
- Factory completed body comes with display model quality finish
- Features VCS (variable camber suspension) that adjusts camber in accordance with suspension stroke
- Coil spring on front suspension can be easily replaced without tools
- Wide range of optional parts is available to be installed
- Kyosho Mini-Z Dodge Challenger SRT Hellcat Redeye B5 MR-020 1/27 Scale AWD Car - RTR
- 2.4GHz Syncro KT-531P transmitter
- 4x AAA alkaline batteries for transmitter
- 4x AAA alkaline batteries for chassis
AGE LEVEL :11 and up
SKILL LEVEL :beginner
BUILD TIME :none
| Model Scale | 1/27 |
| Length | 171mm / 6.7in |
| Width | 75mm / 2.9in |
| Height | 50mm / 1.9in |
| Weight (No Battery) | 193g |
| Wheelbase | 98mm / 3.8in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | AWD (MA-020-W) |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | F : Φ25.0mm×8.5mm R : Φ25.0mm×11.0mm |
| Wheel Hex Size | N/A |
| Tire Tread | F: 64.5mm R: 62.0mm |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | N/A |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | 7.23, 6.38, 6.0, 5.71, 5.97, 5:34, 4.97, 4.5:1 |
| Final Drive Ratio | N/A |
| Pinion | 15T, 17T, 19T, 21T |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | 14 |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | N/A |
| Battery | 8x AAA alkaline (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | N/A |
| Radio | Syncro KT-531P transmitter |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | smooth paved surfaces |
