Official Kyosho Fazer Mk2 FZ02 Subaru Impreza WRC2006 1/10 Scale 4WD Car RTR Thread
  • Official Kyosho Fazer Mk2 FZ02 Subaru Impreza WRC2006 1/10 Scale 4WD Car RTR Thread
    Fazer Mk2 FZ02 Subaru Impreza WRC2006 1/10 Scale 4WD Car - RTR from Kyosho - KYO34426T1
    Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.2V 1800mAh NiMH battery and a battery charger, purchased separately (see Requires below for details).
    For the pure enjoyment of R/C car driving, the combination of a beautifully reproduced car body with the FAZER series chassis can’t be beaten. Kyosho has taken its standard touring car chassis and given it a full model makeover that has evolved performance to a new level. A simplified design with fewer parts has improved maintenance efficiency and reduced weight while core strength and rigidity has been increased through new materials and ribbing and stiffeners on front and rear. In addition, the symmetrical chassis design synergizes excellent front-rear balance through the suspension with responsive control, irrespective of power source.
    Featuring front & rear gear differentials, oil shocks and full ball bearing specs, the high durability and impact resistance allows drivers to unleash the full potential of the chassis. Brake disc wheel hubs with two different offsets (0mm, +5mm) provide compatibility with 190mm and 200mm width body styles and allows the wheelbase to be adjusted to 270mm by replacing some parts (sold separately) for compatibility with other 1/10 scale body styles, in addition the body included. The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, and batteries for the transmitter and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    New Chassis Design
    Chassis features a reduced number and variety of screws by making frequently used screws the same size. Most screws are flat head screws that can be removed with a 2mm hex wrench for easy disassembly.
    Brake Disc Wheel Hub Choices
    Includes choice of two offset brake disc wheel hubs with dummy calipers (for visual styling) that provide compatibility with 190mm and 200mm body widths.
    Optimized Handling
    Handling factors such as bump steer and scrub radius are optimized on the front suspension. Simple ball-connected steering knuckles provide reliable steering and suspension movement. Interchangeable front-rear and left-right hub carriers optimize spare parts utilization and improve maintenance efficiency.
    Light Handling, Precise Control
    New design rebuildable oil shocks mark an evolutionary step up from previous models. Optimal front-rear geometry and balance simultaneously delivers both light handling and precise control.
    Low-Profile Tires
    Original low-profile semi-slick pattern tires produce superior performance and combine with 15-spoke wheels for stunning visuals.
    Wide Range of Gear Ratio Settings
    Standard spur and pinion gear setting is 68T and 32T, but 9 pinion gear settings can be used from 29T – 37T to produce a wide range of gear ratio settings. The new fixed gear mesh motor mount has holes for use with each different pinion gears. Just simply mount the motor directly to the hole locations corresponding to the pinion gear. No gear mesh adjustment is necessary.
    Features:
    • The body is the "Subaru Impreza WRC 2006" that participated in the 2006 World Rally Championship (WRC)
    • Original low-profile semi-slick pattern tires produce superior performance and combine with 15-spoke wheels for stunning visuals
    • Factory-assembled Readyset package only requires 4x AA alkaline batteries for the transmitter, and battery with charger for the chassis
    • Full ball bearings that reduce drive loss equipped throughout the drive system
    • Features KS202W steering servo
    • Sealed differential and transmission deliver reliable performance, even on dusty parking lot surfaces
    • Shaft drive full-time 4WD touring chassis (FZ02)
    • Equipped with a plated dummy brake disc and a painted brake caliper to improve the sense of scale
    • Uses hex head screws in each part. Reliable tightening torque can be applied, and maintenance is possible with even fewer tools
    • Since the motor mount has mounting holes according to the pinion gear, troublesome backlash adjustment is unnecessary. Supports from 29T to 37T
    • Performance can be further enhanced by installing various optional parts
    Includes:
    • Kyosho Fazer Mk2 FZ02 Subaru Impreza WRC2006 1/10 Scale 4WD Car - RTR
    • Completed chassis with R/C radio installed
    • Factory assembled body complete with color scheme
    • Syncro KT-231P+ transmitter
    • Hexagonal wrench
    • Spanner
    • Setting change parts
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :1 hour
    Model Scale 1/10
    Length 456mm / 17.9in
    Width 205mm / 8.0in
    Height 138mm / 5.4in
    Weight (No Battery) 1650g / 58.2oz
    Wheelbase 260mm / 10.2in
    Ground Clearance 8mm
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 66mm x 25mm
    Wheel Hex Size N/A
    Tire Tread 174mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.54:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 60A
    Motor 550 size 14T brushed motor (G14L)
    Battery 4x AA alkaline and 1x 7.2V Ni-MH or 7.4V Li-Po up to 14.8V max (required)
    Servos N/A
    Radio Syncro KT-531P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment smooth paved surfaces
