Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
Designed and built for the pure enjoyment of R/C car driving, the FAZER Mk2 welcomes this brushless motor addition to the series. Powering up from the conventional G14L brushed motor to the TORX 10E brushless motor, the 1.6 x speed boost delivers 65km/h (up from about 40 km/h) backed up by the newly incorporated BRAINZ 10 speed controller, sintered pinion gear and aluminum HD center shaft S (previously an optional upgrade) to support the extra power and higher RPMs.
This fully upgraded version of the VE boasts an ultra-scale 1969 Chevy Camaro Z/28 RS body much loved in America, with a Kyosho designed supercharger, and features light buckets that can be equipped with front and rear LEDs and open/close function for concealed headlights. Kyosho’s original color scheme pays homage to the rebel image of this machine and this 1969 Chevy Camaro Z/28 RS is packaged as a pre-built Readyset, so its easy even for beginners to enjoy without delay. It is also backed by Motion RC's world-renowned customer service and technical support. Drive on!
Lightweight Impact-Resistant Chassis The simple and functional main chassis uses lightweight impact-resistant nylon to reduce weight and an integrated gearbox that optimizes torsional rigidity to deliver a low center of gravity. |
Improved Handling The front suspension optimizes bump steer and scrub radius for improved handling and features interchangeable front left and front right ball-connected steering knuckles that deliver smooth operation and high crash resistance. |
VTA Tires The Kyosho '69 Chevy Camaro Z/28 features VTA tires with compound optimized for brushless motor performance in combination with new color Rostyle type wheels. |
Add Lights For Ultimate Realism Front and rear light buckets are compatible with the 97054 LED light unit series (sold separately). Install the LED light unit to recreate the ultimate Chevy Camaro reality. |
- Ultra-scale body specifications feature concealed headlights with open/close function and a Kyosho designed supercharger
- Elevate the scale finish by installing 97054 LED light unit series (sold separately) in the 4 for the front and 6 for the rear light buckets
- Equipped with high-power TORX 10E motor
- Sintered pinion gear (32T) is equipped as standard to reliably transmit the full power from the motor
- BRAINZ 10 60A ESC with cooling fan provides stable power without overheating
- Equipped with vintage touring car (VTC) tires with compound optimized for brushless performance
- Aluminum center shaft prevents twist and delivers high-RPM drive
- Shaft-driven full-time 4WD touring chassis provides easy handling
- Includes advanced functioning KS4031-06W steering servo as standard
- Factory-completed Readyset only requires 4 x AA batteries for the transmitter as well as a charger and battery for the chassis
- Full ball bearing specifications reduce drive loss in all drive components
- Sealed differential and transmission provide excellent reliability, even in dusty parking lots
- Equipped with a plated dummy brake disc and painted brake caliper for an elevated sense of scale
- Uses hex button head screws throughout. Allows secure torque to be applied and maintenance with fewer tools
- Motor mount has mounting holes according to pinion gear, eliminating the need for tricky backlash adjustment. Supports pinions from 29T to 37T
- Wide range of optional parts are available to further boost driving performance
- Kyosho Fazer Mk2 VE '69 Chevy Camaro Z/28 1/10 Scale 4WD Car - RTR
- Completed chassis with R/C radio installed
- Factory assembled body complete with color scheme
- Syncro KT-231P+ transmitter
- Hex wrenches
- Spanner
- Setting change parts
- 4x AA NiMH batteries - we recommend the Admiral AA NiMH 2600mAh Rechargeable Batteries (Pack of 4)
- 7.4V 4000 - 5000mAh LiPo battery - we recommend the Admiral 5300mAh 2S 7.4V 60C Hard Case LiPo Battery with T Connector
- 2S LiPo compatible battery charger - we recommend the SkyRC e3 11W 3 Cell (3S) Compact AC LiPo Battery Charger
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : 1 Hour
| Model Scale | 1/10 |
| Length | 461mm / 18.1in |
| Width | 210mm / 8.3in |
| Height | 138mm / 5.4in |
| Weight (No Battery) | 1610g / 56.8oz |
| Wheelbase | 260mm / 10.2in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | N/A |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 64mm x 27.7mm |
| Wheel Hex Size | N/A |
| Tire Tread | 167mm |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | Oil-filled |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | 6.54:1 |
| Final Drive Ratio | N/A |
| Pinion | Sintered 32T |
| Spur Gear | 68T |
| Differential | N/A |
| Ball Bearings | Full |
| Brakes | N/A |
| Electronic Speed Control | 60A |
| Motor | TORX 10E brushless |
| Battery | 4x AA alkaline and 1x 7.4V 4000-5000mAh LiPo battery (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | KS4031-06W steering servo |
| Radio | Syncro KT-231P+ transmitter |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | Smooth paved surfaces |
