Official ROC Hobby Beetle "The People's Car" Grey 1/12 Scale 4WD Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	roc-hobby-beetle-the-people-s-car-grey-1-12-scale-4wd-rtr-motion-rc-34352521576633.jpg
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
    Motion RC is pleased to offer to the discerning scaler the new FMS Beetle "The People's Car" 1/12 Scale RTR Mini Crawler for the ultimate in mini scale realism for scale military or gentle off-road applications. The original “Beetle” was designed to be a civilian version of the military Type82E Kommandeurwagen, and features a realistic hard body that features operating LED lights, functional doors with door handles, removable top for back seat access, functional spare tire in a front stowage compartment and much, much more. The Beetle is most certainly a true scale visual and operational experience.
    The Beetle uses a tiny motor contained within the realistic detailed engine compartment to operate engine belts, fan, and pulleys for incredible realism. A two speed transmission, operated from the transmitter allows for 2WD or4WD operation, while the servo-operated, synchronized steering wheel mimics the direction and movement of the front tires, resulting in a uniquely satisfying scale platform.
    Combine the versatile, go-anywhere fun of the ROC Hobby Beetle "The People's Car" Grey 1/12 Scale 4WD RTR with Motion RC’s industry-leading customer service and product support for an unbeatable package!
    Incredible Realism
    The ROC Hobby Beetle features spring-loaded opening doors, fabric-covered seats, and a servo-operated steering wheel that mimics the front tires. Add a 1/12 scale figure (not included) for a final touch of perfect!
    Detailed Undercarriage
    The detailed undercarriage, drive train, and engine compartment serves to enhance the unsurpassed realism afforded by this model.
    Metal Axles, Dogbones, and Central Driveshaft
    The durable, reliable metal drivetrain provides efficient power transfer and resistance to debris, allowing the Beetle to crawl, climb, and drive with confidence.
    Portal Axles
    The Beetle offers rear portal axles that deliver enhanced torque and additional ground clearance to traverse difficult obstacles and tough terrain.
    Features:
    • Realistic paint scheme on molded plastic body
    • Functional LED headlights and taillights
    • Removable top for back seat access
    • Operable front trunk with access to spare tire
    • Operating doors with functional door handles
    • Scale, highly detailed dashboard
    • Servo-operated synchronized steering wheel
    • Soft rubber covered seats
    • Opening engine compartment cover
    • Cooling fan driven by belt
    • Highly detailed, realistic air-cooled horizontally opposed four-cylinder engine
    • Full metal drive shafts
    • 30 stainless steel ball bearings
    • Full metal gears
    • Rear portal axles
    • Four wheel independent suspension
    • Two in one ESC and Receiver
    • Transmitter-operated shift between 2WD and 4WD, Lo and Hi Range
    Includes:
    • ROC Hobby Beetle "The People's Car" Grey 1/12 Scale 4WD - RTR
    • 2.4GHz Transmitter
    • USB Charger
    • 2S 7.4V 380mAh LiPo Battery
    • Tool Kit
    • Owner’s Manual
    Requires:
    • 4x AAA alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 1 Hour
    Model Scale 1/12
    Length 339mm / 13.2in
    Width 139mm / 5.4in
    Height 139mm / 5.4in
    Weight (No Battery) 714g / 25.5in
    Wheelbase 202mm / 7.8in
    Ground Clearance 28mm / 1.2in
    Body Molded hard plastic, factory painted and decorated
    Chassis Composite
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 58mm x 12mm
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel torsion
    Shock Type N/A
    Transmission 2-Speed, 2WD/4WD
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control Integrated ESC/RX/Light Controller
    Motor Brushed 130-size
    Battery 2S 7.4V 380mAh LiPo
    Servos Three (micro)
    Radio 4-Channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 1 hour
