I have my second 1580 V4. The first had a mind of it's own out of the box. The second after about 30 min run time started acting up. All is good except when I run the main boom up it stutters.
Meaning while moving up full command it stops, goes, stops, goes, several time until it reaches the limit switch. Checked connections and all are good. also found two magnets on the down boom limit switch and one on the up limit. also the up limit did not work- it would run until it maxed out. I moved the second limit switch mag from the down to the up side (now double mags) and it limits as it should. Id rather figure this out instead of returning a second one........
