Official Kabolite K180-100S 1/14 Scale Hydraulic Forklift Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Bring warehouse and construction operations to life with the Kabolite K180-100S, one of the most detailed and capable hydraulic RC forklifts available. Built almost entirely from metal and equipped with a true hydraulic lifting system, the K180-100S delivers the power, precision, and realism serious RC construction enthusiasts’ demand. Whether you're stacking scale pallets, loading trailers, or building the ultimate RC logistics yard, the K180-100S combines exceptional scale fidelity with smooth proportional hydraulic operation.
    Unlike other RC forklifts, the K180-100S uses a genuine hydraulic system that provides smooth, scale-speed lifting with impressive control. The metal mast and forks are capable of lifting loads up to 2.5kg (5.5 lbs.), making it ideal for handling scale pallets, lumber, pipes, concrete blocks, and other RC construction accessories. The included FlySky FS-ST8 2.4GHz radio system delivers precision control of the functions, including direction, speed, lifting, tilt, fork spacing, lights, sound, and more. The included 11.1v 3S 5000mAh LiPo battery pack and AC charger offers sufficient power for long work sessions, while the durable carrying case keeps the model safe for storage or transportation.
    Tough, versatile, and loaded with power, this forklift is the perfect choice for RC enthusiasts who want a premium, ready-to-use experience, and when combined with Motion RC’s industry-leading service, selection, and support, you have something to “build on”. Get moving!
    Fully Assembled and Ready to Work
    The K180 arrives fully assembled and ready to use. Simply add hydraulic fluid (included), charge the included LiPo battery, and install 4 AA alkaline batteries in the transmitter (available separately, not included) to begin your material handling journey.
    Easy Access
    The high-capacity 11.1V 3S 500mAh LiPo is easily accessed through the rear hatch of the K180.
    Hydraulic Fork Positioners
    Elegantly engineered and manufactured, the forks are hydraulically adjustable for with for the ultimate in realistic material handling operations.
    LED Lights and Sound
    The K180 includes an integrated light and sound system that delivers an extra level of realism to every job. Functional lighting includes headlights, brake lights, reverse lights, taillights, a roof-mounted warning beacon, and roof spotlights. Authentic sound effects include the horn, engine, reverse alarm, and hydraulic operation sounds. Turn signals are not included.
    Note: The sound module must be activated before the front and rear lights can be switched on.
    Impressive Lifting Capacity
    The robust hydraulic system included on the K180 provides a lifting capacity of more than 5 lbs. (2.5Kg)
    Advanced Engineering
    The master hydraulic control valve is an impressive display of design and manufacturing that serves to delight both collectors and operators alike.
    • Ready-to-Run (RTR) with FlySky ST8 radio, battery, and charger included
    • Nearly all-metal construction for exceptional durability and scale realism
    • True hydraulic mast with smooth proportional lifting
    • 3-way hydraulic valve system for realistic forklift operation
    • Front-wheel drive with differential
    • Rear-wheel servo steering for tight maneuverability
    • Adjustable hydraulic pressure
    • Functional LED lighting system
    • Integrated sound system with engine, horn, reverse, and hydraulic sounds
    • Opening cab details with realistic interior
    • Electric windshield wiper
    • Digital onboard voltage display
    • External hydraulic oil sight window
    • Main power switch for convenient operation
    • Kabolite K180-100S 1/14 Scale Hydraulic Forklift - RTR
    • FlySky FS-ST8 8-channel 2.4GHz radio system
    • Receiver
    • Installed motor(s)
    • Hobbywing 1060 ESC
    • Hydraulic system
    • Lighting system
    • Sound system
    • 11.1V 3S 5000mAh LiPo battery
    • AC Battery charger
    • Hydraulic fluid and filler bottle
    • Instruction manual
    • Stickers
    • Tools
    • Carrying case
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 30 Minutes
    Scale 1/14
    Length 470mm / 18.5in
    Width 185mm / 7.3in
    Height 283mm / 11.1in
    Weight 8,500g / 303.6oz
    Body Material Metal
    Chassis Material Metal
    Track Material N/A
    Motors Brushless
    House Rotation No
    Lights Yes
    Sound Yes
    Exhaust Effect No
    Required Battery 3S 11.1V 5000mAh LiPo (included)
    Required Radio FlySky ST-8 (included)
    Skill Level Intermediate
    Build Time 30 minutes
    Operating Time 45-60 minutes continuous
  • JA1170squad
    Occasional Rivet Counter.
    • Jul 2026
    • 46
    • United States Of America
    Hello I am a rc plane person but I don’t understand how there is a difficulty in driving it is there like a speed or handiling enhancement
