Hooben stuff
  • DavidN
    It came with the base color like that. I just applied the camouflage decals on.
  • tank_me
    DavidN Did your ZTZ-99A come that color or did you change the base color? Mine came in a lot lighter shade of sand. If you did respray it, what color/brand is that? I've been looking a all kinds of tan/sand paint and can't seem to find one that I like for my Hooben ZTZ-99A. They are either too brown, too orange, too pink, too light, or too dark. That one seems to look better than most I've looked at.
    Thanks.
  • gzt4gs
    Hi, I have just bought the hooben 1/16 wwi british mark iv (male) heavy rc metal tank kit no. 6676. Does anyone know what battery I should buy?
  • Sureshot
    Reminds me of Legos...
  • DavidN
ID:	406864 Click image for larger version
  • DavidN
ID:	406860 Click image for larger version
ID:	406861 Click image for larger version
  • DavidN
ID:	406856 Click image for larger version
ID:	406857 Click image for larger version
  • DavidN
    My Hooben ZTZ-99 is done.
ID:	406852 Click image for larger version
ID:	406853 Click image for larger version
  • Handy Lance
    Originally posted by quitcherbitchen View Post
    Does anyone actually have an up graded CNC enclosed gearbox? I have a second T-55 that I got second hand that is missing the motor. I would like to know if it is worth it.
    I have both
    HL version CNC enclosed
    vs stamped chassis open version
    quieter
    smoother running
    heavier
    had to refab mounts from bottom
    pricy
    I am glad I disassembled my gearboxs upon arrival. Some crazy grease in 1 spot inside tranny, doing nothing. Also, filings, and dirtish stuff. I found the CNC version acts as a great heat sink for the motors.
    Once properly cleaned, shimmed and greased the CNC enclosed gearbox is much better.
    Price though👎🏻
  • tank_me
    I have several of the HL versions. I like them. Had no issues and they run great in my heavy Taigen hulled KV-1 and SU-152. Can't comment on the Hooben versions, but they look like they use a double flat on the output shaft instead of the single flat like on a Heng Long. Also, it doesn't state shaft length or if they are high/low (HL) or mid/low (ML) motor placement. For the T55, I would go with a mid/low version of the gearboxes as the standard Hooben gearbox on mine seems to make contact with the upper deck. I don't have any clue what the length of the shaft is though.
  • quitcherbitchen
  • tank_me
    There are two different versions of the Hooben enclosed gearbox. One type is basically a clone of the HL "CNC gearbox" and the other is larger made for larger 1/10th scale tanks that says it can take a 550 or 775 motor. I wanted to know what the drive shaft dimensions were for those to see if they'd work for my 1/10th scale project Jadgtiger, but I made other arrangements at this point. Hooben didn't want my money I guess.
  • RichJohnson
    to my knowledge all Hooben 1/16 tanks have come with the same transmission/gearboxes. The Mierkava and the leopard 1a5 have the same gear boxes as well as the fury ez8 Sherman. They use standard flanged ball bearings, and the shielding on the race falls off all the balls fall out and the ball bearing disintegrates within a short amount of lifespan use. I experienced a driveshaft break because the ends are shouldered smaller to fit into the ball bearings when the ball bearing fell apart the gear mesh put lateral pressure on the gear shaft and snapped the shoulder end off because it was now crooked and pushing against the open disintegrated ball bearing housing rather than spinning. Once I replaced all the bearings and the broken shaft they were fine. The transmissions have been running fine since. I have run longer now than they did before the first bearings failed
    plenty of photos of the tranys and damage is posted un those reviews on rcuniverse
  • keilau
    I've never seen a Hooben that came with the nicer enclosed gearboxes. Both of mine have the same open gearboxes. I enquired about the enclosed ones for a 1/10th tank and never got Hooben to respond to my inquiry.
    Hooben advertise the slightly modified Heng Long CNC gearbox for their 1/16 scale RC tanks.
    Originally posted by hooben
    HOOBEN New Released Scale 1/16 All Metal Closed CNC Gearbox Fit all HOOBEN Or HL TANKS Available in 1/37 and 1/56 speed ratios Matches all HOOBEN TANKS And Henglong Tanks.
  • tank_me
  • keilau
    Originally posted by RichJohnson View Post
    My first advice is to remove the transmissions, disassemble them and replace all the ball bearings as they failed one by one in each tank I had until i just replaced the rest of them.
    my review on my mark4M is very long and comprehensive. I really don’t see how anyone could get a positive take on it for a general rc enthusiast if you read it carefully. In short the first 15 feet of running a wheel broke off. Most of the others did as well, requiring me to have the wheel arm redesigned by a 3d guy before I linked up with JVM, and then use shapeways to print all new arms.
    everything seems to break on the tank very easily. The turret has squashed itself due to lack of support framework in it. I have used a heat gun to reshape the turret a few times and then brace it but it still sags more. It’s just too large and thin and soft of a 3d print material for use in the sun for very long or to be in a warm garage.
    my leoaprd 1a5 lost all its bearings as well however the tank model has held up much better. It’s smaller with more support and I ordered the metal edition which is the only version I recommended if you buy a hooben and want to run it.
    for the Merkava, if they make a metal edition buy it and be careful and don’t leave it in the sun if you really have to have one.
    Do you mean the gearbox when you referred to "transmission"? I went to the Hooben website and found only the HL CNC gearbox for their 1:16 scale tanks. Did they package a different gearbox in the Leo 1A5 and Merkava 4M?
    In DavidN pictures of the Hooben interior, the gearbox seemed to be an open frame gearbox with sleeve bearings. Not an acceptable pairing for the Hooben price point. Can you show some picture of the transmission failed bearings?
  • quitcherbitchen
    Any advice on the what bearings to get?
  • RichJohnson
  • keilau
    Originally posted by DavidN View Post
    They are all the same....
    The ZTZ99...
    The Cromwell....
    The Tiger I...
    Do they all have the same plastic on plastic idler wheels like tank_me ZTZ99?
  • DavidN
    I am interested in the motors. Are there differences between the models?
    The ZTZ99...
    The Cromwell....
    The Tiger I...
