Tamiya Ford Aeromax 1/14 Scale Semi Truck - KIT
Version Info: This truck is a KIT. Assembly and painting is required. A plain white cab comes out of the box ready for paint. Photos show a completed and painted model. Minimum 4+ channel radio system, ESC, battery, charger and servos will need to be purchased separately.
Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya Ford Aeromax resembles the classic conventional American tractor truck. Powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The Ford Aeromax's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. With its base-white cab and decal set, explore endless customization possibilities to build this KIT from the ground up and create your personalized dream scale hauler!
Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
Visit the product page here. ![]() |
540-Sized Motor and 3-Speed Transmission The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles. |
| Exceptional Scale Detail Scale details surround this truck for exceptional realism. |
Dual Rear Axles Each axle is supported with leaf spring and shocks. |
| Choose Your Own Paint Colors The cab comes plain white out of the box so you can choose any colors you wish to paint and finish your truck in style. |
1/14 Scale This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport. |
| Add Your Own Electronics and Drive! Once you add your preferred electronics you're ready for those on-road adventures. |
- Exceptional scale detail and realism brings this truck to life on every level
- Includes a powerful 540-sized brushed motor driven by a 3-speed transmission
- Dual rear axles each supported with leaf spring and shocks
- Cab comes out of the box white so you can paint your chosen custom scheme
