Official Thread: Tamiya Volvo FH16 Globetrotter 750 1/14 Scale Timber Truck
  • James
    Administrator
    • Aug 2017
    • 1543
    Tamiya Volvo FH16 Globetrotter 750 1/14 Scale Timber Truck - KIT
    Version Info: This truck is a KIT. Assembly and painting is required. A plain white cab comes out of the box ready for paint. Photos show a completed and painted model. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
    Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya Volvo FH16 Globetrotter 750 is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The Volvo FH16 Globetrotter 750's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. With its base-white cab and decal set, explore endless customization possibilities to build this KIT from the ground up and create your personalized dream scale hauler!
    Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Visit the Product Page HERE for more information:
    540-Sized Motor and 3-Speed Transmission
    The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles.
    Exceptional Scale Detail
    Scale details surround this truck for exceptional realism.
    Dual Rear Axles
    Each axle is supported with leaf spring and shocks.
    Choose Your Own Paint Colors
    The cab comes plain white out of the box so you can choose any colors you wish to paint and finish your truck in style.
    1/14 Scale
    This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport.
    Add Your Own Electronics and Drive!
    Once you add your preferred electronics you're ready for those on-road adventures.
    FEATURES:
    • Exceptional scale detail and realism brings this truck to life on every level
    • Accurate interior details such as dashboard and seats
    • ABS plastic body captures the FH16 Globetrotter form, with stainless steel photo-etched front grille, and cab interior details
    • Depictions of stakes and cab rear headboard use a durable combination of resin and metal
    • Power from the front-mounted motor is delivered to rear axles via propeller shaft. A built-in differential gear on each axle enables smooth cornering
    • Highly-realistic suspension utilizes metal leaf springs and friction damper
    • The model enjoys easy driving thanks to the float-mounted die-cast front and reinforced resin rear axles
    • TR Mighty Tuned motor (35T) provides plenty of power, even when driving with loads
    • Includes a powerful 540-sized brushed motor driven by a 3-speed transmission
    • Dual rear axles each supported with leaf spring and shocks
    • Cab comes out of the box white so you can paint your chosen custom scheme
  • Peterboi
    Rc Stinger
    • Aug 2019
    • 16
    • NEW ZEALAND
    Very Nice looks great
