Official Kyosho 1/12 Scale Blizzard 2.0 ReadySet All Terrain Snow Cat - RTR Thread
  • jbaartz
    • Sep 2020
    • 481
    Blizzard 2.0 1/12 Scale ReadySet All Terrain Snow Cat - RTR from Kyosho - KYO34902
    Version Info: This ATTV is delivered as "RTR", however does require 4x AA batteries for the transmitter (see Requires below for details).
    The Kyosho Blizzard 2.0 1/12 Scale ReadySet All Terrain Snow Cat with 2.4GHz Radio is a belt-tracked vehicle that powers over sand, dirt and snow! When paired with the user-friendly Readyset with 2.4GHz R/C system you also have blade arm control. Powered by two independent side-by-side motors, the transmission in the Blizzard 2.0 Readyset delivers impressive power and free control, giving the driver dominance over any terrain like only a true belted vehicle can deliver. With a suspension system equipped on all wheels, the Blizzard clears every challenge in its path including rocky obstacles, steep hill climbs and gravel or sand that would trap a machine with normal tires. Twin 370 motors and twin ESCs deliver forward, reverse, left/right turning and pivot (turns on the spot). In addition, control of the blade arm with the transmitter adds another fascinating aspect to the Blizzard. For great fun in the sand or snow, the Blizzard can match your outdoor lifestyle and go wherever you want to go.
    Your Kyosho ATTV is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    NEW ESCs
    New ESCs with standard type motor connectors are compatible with NiMH and LiPo batteries.
    Ready To Run (RTR)
    Includes 2.4GHz KT-431S 4-channel stick transmitter and 6-channel KR-632 receiver.
    Large Radio Box
    The radio box has more than enough room to fit both receiver and speed controller. The new design even allows the large capacity KA060-91W (No.82245) waterproof speed controller to be installed if desired.
    Battery and Charger
    Includes KYOSHO SPEED HOUSE 2200mAh NiMH battery and USB charger that is compatible with NiMH/NiCd batteries only. Battery connector is 2P Super Plug.
    FEATURES:
    • Scale realistic body combines a wide cabin design with red body color and detailed components such as mirrors, air intake bulges and rotating light
    • ESC for the motor control is compatible with NiMH and NiCd batteries as well as the higher power output of LiPo batteries
    • Includes 2.4GHz KT-431S 4-channel stick transmitter and 6-channel KR-632 receiver. Also equipped with high-torque KS4031-06W servo for the dozer blade.
    • The radio box has more than enough room to fit both receiver and speed controller
    • Motor connectors feature highly flexible bullet terminals. Locker type main switch allows smooth ON-OFF function
    • Power supply harness between the battery and speed controller uses a high-efficiency 2P Super Plug connection. It can also be easily converted for a standard speed controller
    • Includes Kyosho Speed House 2200mAh NiMH battery and USB charger that is compatible with NiMH/NiCd batteries. Battery connector is 2P Super Plug
    • Optional ‘Heavy Metal Caterpillar’ tracks (BLW2B) increase weight and scale feel. The tracks incorporate rubber to minimize loss and deliver smooth movement
    • Roller can also be operated with the motor using optional Rear Tiller Unit Set (BLW3). The unit can be operated separately using the 4th channel on the transmitter
    INCLUDES:
    • Kyosho Blizzard 2.0 1/12 Scale ReadySet All Terrain Snow Cat - RTR
    • Pre-assembled chassis with control linkages complete
    • Complete printed body
    • 2.4GHz Syncro KT-431S R/C system
    • Kyosho Speed House NiMH 2200 battery
    • USB charger
    • Binding connector
    • Tool (1.5 mm hex wrench)
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/12
    Length 365mm / 14.3in
    Width 320mm / 12.5in
    Height 220mm / 8.6in
    Weight (With Battery) N/A
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Chain drive
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 2x KA-1571 ESC unit (S plug)
    Motor 2x 370 type
    Battery 7.2V 2200mAh NiMH battery (included)
    Servos 1
    Radio 2.4GHz Syncro KT-431S
    Lights Yes
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time None
    Recommended Environment Offroad
  • CM_Aero
    • Nov 2018
    • 183
    • Central Texas
    Been having fun with the Snowcat here in Texas the past few days. The snow was very fine and dry and I first thought the cat would have trouble getting around. But nope! It just floated on top of the snow. Got about 6 1/2 inches here in Central Texas.
    • Marco Polo
      Go NAVY
      • Aug 2012
      • 590
      • Illinois
      I was hoping someone would post their Snowcat photos will all the snow we are having in the US. I never thought it would be someone from Texas... crazy weather. Thank you for sharing.
      • CM_Aero
        • Nov 2018
        • 183
        • Central Texas
        Yea! I've always wanted one of these. Cant believe it snowed twice here this year! I need to reinforce the fuse to hold the Insta360. It kept falling off the top using double sided tape.
