Official Kyosho 1/12 Scale Trail King ReadySet All Terrain Tracks Vehicle - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Trail King 1/12 Scale ReadySet All Terrain Tracks Vehicle (Yellow) - RTR from Kyosho - KYO34903T1
    Trail King 1/12 Scale ReadySet All Terrain Tracks Vehicle (Blue) - RTR from Kyosho - KYO34903T2
    Version Info: This ATTV is delivered as "RTR", however does require 4x AA batteries for the transmitter (see Requires below for details).
    The newest edition to the 1/12 scale electric belt vehicle series further enhances your outdoor experience. Kyosho’s long selling ‘Blizzard’ that has stood the test of time with a legion of loyal fans, has been used as a base for the new ‘Trail King’. Among its many features, a completely new body design creates the retro feel of a hard working machine. In addition to the realistic finish with separate accessory parts, the underbody incorporates a cockpit and always-on front and rear LED lights. A loading platform also provides space for a variety of things to be carried.
    The Trail King enhances the enjoyment of nostalgic wilderness experiences across a wide variety of scenes with a chassis boasting heavy-duty specifications for smooth and easy travel across any surface including uneven rocky roads and steep gradients. Take control with forward, reverse, left/right and the complete left/right pivot turning capability of a belt vehicle. As the model is fully pre-assembled, the advanced mechanics of the Trail King are ready to be enjoyed straight away. Compatibility with spare and optional parts for the Kyosho ‘Blizzard’ allows you to expand your enjoyment of the snow and sand adventures even further.
    Your Kyosho ATTV is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Scale Realism
    Injection molded accessory parts such as mirrors, wipers and loading platform combine with the underbody and driver’s seat to produce an incredible level of scale realism.
    Power and Durability
    Two-motor transmission produces the independent left/right control for flexible maneuverability and powerful drive of a belt vehicle. Simple box structure of the chassis provides easy maintenance and excellent durability.
    LED Lights
    Two white LED lights on the front and two red LEDs on the rear (both always on) are equipped as standard and incorporated into the bumpers mounted on the chassis. No difficult disconnecting of the LED wiring is required when attaching and detaching the body.
    Ready To Run (RTR)
    Comes RTR out of the box. All you need are 4x AA batteries for the transmitter and you're ready to go.
    FEATURES:
    • Injection molded accessory parts such as mirrors, wipers and loading platform combine with the underbody and driver’s seat to produce an incredible level of scale realism
    • Two-motor transmission produces the independent left/right control for flexible maneuverability and powerful drive of a belt vehicle. Simple box structure of the chassis provides easy maintenance and excellent durability
    • Two white LED lights on the front and two red LEDs on the rear (both always on) are equipped as standard and incorporated into the bumpers mounted on the chassis. No difficult disconnecting of the LED wiring is required when attaching and detaching the body
    • Other optional accessory parts are available to increase the scale finish and add individual style to your machine
    INCLUDES:
    • Kyosho Trail King 1/12 Scale ReadySet All Terrain Tracks Vehicle (Yellow) - RTR
    • Completed chassis
    • Transmitter
    • Receiver
    • 2200mAh NiMH battery
    • USB charger
    • Binding connector
    • Tool (1.5mm Hex wrench)
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/12
    Length 360mm / 14.1in
    Width 310mm / 12.2in
    Height 200mm / 7.8in
    Weight (With Battery) 1610g / 56.7oz
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Chain drive
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery 7.2V 2200mAh NiMH battery (included)
    Servos N/A
    Radio N/A
    Lights Yes
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time None
    Recommended Environment Offroad
