Official Tamiya 1/14 Scale 3-Axle Reefer Trailer Plastic Model - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    3-Axle Reefer Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56319
    Version Info: This trailer is a KIT. Assembly is required.
    A common site on the roads of Europe, the 3-axle refrigeration "reefer" trailer has been added to Tamiya's unique lineup of 1/14 R/C Tractor Truck products. Featuring an aluminum frame with durable ABS panels, this trailer also has such details as a refrigeration unit and a tailgate that can be fully opened. Aluminum side frames and resin cross members make up the chassis, which comes with realistically reproduced leaf-spring suspension. Other details such as storage box and spare tire are also included.
    Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck
    Hith this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road.
    Exceptional Scale Detail
    Scale details surround this trailer for exceptional realism.
    Functional Refrigeration Unit and Tailgate
    This trailer has such details as a refrigeration unit and a tailgate that can be fully opened.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    FEATURES:
    • Aluminum frame with durable ABS panels
    • Functional refrigeration unit and a tailgate that can be fully opened
    • Aluminum side frames and resin cross members make up the chassis
    • Chassis comes with realistically reproduced leaf-spring suspension
    • Other details such as storage box and spare tire included
    INCLUDES:
    • Tamiya 3-Axle Reefer Trailer 1/14 Scale Plastic Model - KIT
    • Storage box and spare tire
    REQUIRES:
    • Tamiya 1/14 Scale Tractor Trailer Truck
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length N/A
    Width N/A
    Height N/A
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance N/A
    Body N/A
    Chassis Aluminum & Plastic
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery N/A
    Servos N/A
    Radio N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
