3-Axle Reefer Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56319
Version Info: This trailer is a KIT. Assembly is required.
A common site on the roads of Europe, the 3-axle refrigeration "reefer" trailer has been added to Tamiya's unique lineup of 1/14 R/C Tractor Truck products. Featuring an aluminum frame with durable ABS panels, this trailer also has such details as a refrigeration unit and a tailgate that can be fully opened. Aluminum side frames and resin cross members make up the chassis, which comes with realistically reproduced leaf-spring suspension. Other details such as storage box and spare tire are also included.
Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck Hith this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road. |
| Exceptional Scale Detail Scale details surround this trailer for exceptional realism. |
Functional Refrigeration Unit and Tailgate This trailer has such details as a refrigeration unit and a tailgate that can be fully opened. |
| Optional Light and Sound Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03. |
- Aluminum frame with durable ABS panels
- Functional refrigeration unit and a tailgate that can be fully opened
- Aluminum side frames and resin cross members make up the chassis
- Chassis comes with realistically reproduced leaf-spring suspension
- Other details such as storage box and spare tire included
- Tamiya 3-Axle Reefer Trailer 1/14 Scale Plastic Model - KIT
- Storage box and spare tire
- Tamiya 1/14 Scale Tractor Trailer Truck
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
| Model Scale | 1/14 |
| Length | N/A |
| Width | N/A |
| Height | N/A |
| Weight (No Battery) | N/A |
| Wheelbase | N/A |
| Ground Clearance | N/A |
| Body | N/A |
| Chassis | Aluminum & Plastic |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | Metal and Plastic |
| Suspension | Leaf Spring |
| Shock Type | Friction Damper |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | N/A |
| Battery | N/A |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | N/A |
| Radio | N/A |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 3+ Hours |
| Recommended Environment | On-road, smooth, paved surfaces |
