Official Tamiya 1/14 Scale Box Trailer Plastic Model - KIT Thread
  • jbaartz
    • Sep 2020
    • 483
    Box Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56302
    Version Info: This trailer is a KIT. Assembly is required.
    This Box Trailer can be hitched to a Tamiya 1/14 scale R/C tractor truck. This trailer uses hard-anodized aluminum parts for the utmost durability and realism. Rear gate doors are openable, just as seen on full-sized trailers.
    Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck
    Hitch this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road.
    Exceptional Scale Detail
    Scale details surround this trailer for exceptional realism.
    Rear Gates Open and Close
    To extend the scale experience the trailer's rear gates open and close.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    FEATURES:
    • Exceptional scale detail and realism brings this trailer to life on every level
    • Hard-anodized aluminum parts for the utmost durability and realism
    • Rear gate doors are openable, just as seen on full-sized trailers
    INCLUDES:
    • Tamiya Box Trailer 1/14 Scale Plastic Model - KIT
    REQUIRES:
    • Tamiya 1/14 Scale Tractor Trailer Truck
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length 886mm / 34.8in
    Width 186mm / 7.3in
    Height N/A
    Weight (No Battery) 5360g / 189.0oz
    Wheelbase N/A
    Ground Clearance N/A
    Body N/A
    Chassis Aluminum
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread Front: N/A / Rear: 138mm
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery N/A
    Servos N/A
    Radio N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
