Official Tamiya 1/14 Scale Flatbed Semi-Trailer Plastic Model - KIT Thread
  • jbaartz
    • Sep 2020
    • 483
    Flatbed Semi-Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56306
    Version Info: This trailer is a KIT. Assembly is required.
    This highly realistic 1/14 scale flatbed semi-trailer model is for use in combination with Tamiya's 1/14 scale R/C tractor trucks. A scale appearance is achieved by using authentic components such as aluminum chassis/frame, wood-floored platform and actual chains.
    Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck
    Hith this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road.
    Exceptional Scale Detail
    Scale details surround this trailer for exceptional realism.
    Wood-Floored Platform
    The wood flooring adds that extra dimension of scale realism and detail.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    FEATURES:
    • Exceptional scale detail and realism brings this trailer to life on every level
    • Hard-anodized aluminum parts for the utmost durability and realism
    • Rear gate doors are openable, just as seen on full-sized trailers
    INCLUDES:
    • Tamiya Flatbed Semi-Trailer 1/14 Scale Plastic Model - KIT
    REQUIRES:
    • Tamiya 1/14 Scale Tractor Trailer Truck
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length 711mm / 27.9in
    Width 193mm / 7.6in
    Height N/A
    Weight (No Battery) 2480g / 87.4oz
    Wheelbase N/A
    Ground Clearance N/A
    Body N/A
    Chassis Aluminum
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread Front: N/A / Rear: 138mm
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery N/A
    Servos N/A
    Radio N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
