Official Tamiya 1/14 Scale Fuel Tanker Trailer Scale Plastic Model - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    Fuel Tanker Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56333
    Version Info: This trailer is a KIT. Assembly is required.
    The Tamiya 1/14 scale Fuel Tank Trailer has been revamped! This fuel tank trailer features a newly-designed original and imagined livery that was inspired by fuel tank trailers seen in the United States.
    Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck
    Hitch this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road.
    Exceptional Scale Detail
    Scale details surround this trailer for exceptional realism.
    Retractable Support Legs
    Equipped with support legs which automatically retract when coupling with a tractor truck.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    FEATURES:
    • Fuel tank section has been beautifully reproduced in stainless steel, with upper and lower decks made from aluminum
    • Equipped with support legs which automatically retract when coupling with a tractor truck
    • Stickers included to depict the newly-designed original livery
    INCLUDES:
    • Tamiya Fuel Tanker Trailer 1/14 Scale Plastic Model - KIT
    • Decals
    REQUIRES:
    • Tamiya 1/14 Scale Tractor Trailer Truck
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length 814mm / 32.0in
    Width N/A
    Height N/A
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance N/A
    Body Aluminum
    Chassis Aluminum
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery N/A
    Servos N/A
    Radio N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
