Official Tamiya 1/14 Scale Grand Hauler Black Edition Semi Truck - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    Grand Hauler Black Edition 1/14 Scale Semi Truck - KIT from Tamiya - TAM56356
    Version Info: This truck is a KIT. Assembly is required. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
    This is a special edition of the Grand Hauler. The R/C model assembly kit recreates a massive boxy, customized truck like those seen in North America. The special edition version is a great option for those without the time or confidence to apply a paint job to their kit, as the body, and other key body parts are pre-painted Metallic black (Tamiya Color TS-40). Additionally, a matte coating is applied over the metallic black which provides a cool look as seen in current trends in the automotive scene.
    Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya Grand Hauler Black Edition is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The Grand Hauler Black Edition's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    540-Sized Motor and 3-Speed Transmission
    The included 540-sized brushed motor is driven by the 3-speed transmission which has no problem turning the dual rear axles.
    Exceptional Scale Detail
    Scale details surround this truck for exceptional realism.
    Dual Rear Axles
    Each axle is supported with leaf spring and shocks.
    Optional Light and Sound
    Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03.
    1/14 Scale
    This truck comes in an impressive 1/14 scale. Coming in at over 2 feet in length, it has an ideal on-road presence while being convenient to transport.
    Add Your Own Electronics and Drive!
    Once you add your preferred electronics you're ready for those on-road adventures.
    FEATURES:
    • Exceptional scale detail and realism brings this truck to life on every level
    • Body parts are molded in black, pre-painted in Metallic black (TS-40), and given a matte urethane top coat
    • Metal plated parts include bumpers, radiator grille, roof-top horn and light bezel parts, side and curb mirrors, air cleaners, mufflers and more!
    • 3-axle chassis utilizes a tough ladder frame with aluminum side channels and resin cross members. A realistic drivetrain setup sees the front mounted motor powering twin rear axles
    • 3-speed transmission can be controlled via a separately sold 4ch R/C transmitter
    • Metal leaf spring dampers with built-in coil springs provide durable suspension
    • Coupler is included to enable connection with any currently available Tamiya 1/14 scale trailer
    • Compatible with separately-sold Multi-Function Control Unit MFC-01 or MFC-03 for realistic LED lights and sounds
    INCLUDES:
    • Tamiya Grand Hauler Black Edition 1/14 Scale Semi Truck - KIT
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length 692mm / 27.2in
    Width 192mm / 7.5in
    Height 330mm / 12.9in
    Weight (No Battery) N/A
    Wheelbase 272mm / 10.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Aluminum
    Drivetrain 3-Speed
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission 3-Speed
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control 6 Cell 7.2V NiMH Brushed ESC (required)
    Motor 540-Brushed
    Battery 7.2V 1600mAh (required)
    Servos 1x standard size (required)
    Radio 4+ Channel (required)
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
  • JIMSIX
    • 3
    What transmission can I put in with revers in my Tamiya Grand Hauler
