Maersk Container Trailer 1/14 Scale Plastic Model - KIT from Tamiya - TAM56326
Version Info: This trailer is a KIT. Assembly is required.
Cargo containers are used for shipping products and raw materials all around the world and ISO. This is a replica of a 40ft. regular height container which can be connected to any of Tamiya's 1/14 scale Tractor Trucks.
Hitch Up To a Tamiya 1/14 Scale R/C Tractor Truck Hitch this trailer up to any compatible Tamiya 1/14 scale truck for an exceptional scale experience both static and on the road. |
| Exceptional Scale Detail Scale details surround this trailer for exceptional realism. |
Twist-Lock System Features the same twist-lock system as the actual container to enable attachment/detachment from the trailer. |
| Optional Light and Sound Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03. |
- The container features the same gray livery as that of the shipping company MAERSK
- Container side, top, and front panels feature different panel patterns which are accurately reproduced
- Features the same twist-lock system as the actual container to enable attachment/detachment from the trailer
- 3-axle semi-trailer designed for loading one 40ft. or two 20ft. containers, which is most commonly seen in Europe and is realistically reproduced and provides a great scale presence
- Tamiya Maersk Container Trailer 1/14 Scale Plastic Model - KIT
- Tamiya 1/14 Scale Tractor Trailer Truck
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
| Model Scale | 1/14 |
| Length | 917mm / 36.1in |
| Width | 188mm / 7.4in |
| Height | 300mm / 11.8in |
| Weight (No Battery) | N/A |
| Wheelbase | N/A |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | Aluminum |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | Metal and Plastic |
| Suspension | Leaf Spring |
| Shock Type | Friction Damper |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | N/A |
| Battery | N/A |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | N/A |
| Radio | N/A |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 3+ Hours |
| Recommended Environment | On-road, smooth, paved surfaces |
