Official Tamiya 1/14 Scale MAN TGX 18.540 4X2 XLX Semi Truck - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    MAN TGX 18.540 4X2 XLX 1/14 Scale Semi Truck - KIT from Tamiya - TAM56350
    Version Info: This truck is a KIT. Assembly is required. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
    This is a special edition of the 1/14 R/C MAN TGX 18.540 4x2 XLX assembly kit. It comes with body components, which are beautifully pre-painted in Tamiya TS-10 French Blue (clear topcoat applied), with a durable coating applied to protect the paintwork from damage.
    Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya MAN TGX 18.540 4x2 XLX is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins one axle supported on a realistic leaf spring and shock suspension. The MAN TGX 18.540 4x2 XLX's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    540-Sized Motor and 3-Speed Transmission
    The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive the axle.
    Exceptional Scale Detail
    Scale details surround this truck for exceptional realism.
    Rear Axle
    Each axle is supported with leaf spring and shocks.
    LED Light Buckets
    You can install your own LED lights (sold separately) to further the scale appeal.
    1/14 Scale
    This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport.
    Add Your Own Electronics and Drive!
    Once you add your preferred electronics you're ready for those on-road adventures.
    FEATURES:
    • Exceptional scale detail and realism brings this truck to life on every level
    • The realistic interior includes seats and dashboard while metal-plated parts as well as metal transfer emblems enhance exterior detail
    • The included coupler enables connection with any currently available Tamiya 1/14 scale trailer
    • Cabin tilts forward just like the actual truck
    • Metal leaf springs and friction dampers enable realistic suspension movement
    • When controlled with a separately available R/C system, the 3-speed transmission enables authentic gear changes while driving
    • The model features a realistic body and a 3-axle chassis with durable ladder frame
    • Cab, F, H, K, M and CC parts are replaced with pre-painted Gun Metal color parts
    INCLUDES:
    • Tamiya MAN TGX 18.540 4X2 XLX 1/14 Scale Semi Truck - KIT
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 3+ HOURS
    Model Scale 1/14
    Length 458mm / 18.0in
    Width 193mm / 7.5in
    Height 298mm / 11.7in
    Weight (No Battery) N/A
    Wheelbase 272mm / 10.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Aluminum
    Drivetrain 3-Speed
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material Metal and Plastic
    Suspension Leaf Spring
    Shock Type Friction Damper
    Transmission 3-Speed
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control 6 Cell 7.2V NiMH Brushed ESC (required)
    Motor 540-Brushed
    Battery 7.2V 1600mAh (required)
    Servos 1x standard size (required)
    Radio 4+ Channel (required)
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 3+ Hours
    Recommended Environment On-road, smooth, paved surfaces
