MAN TGX 18.540 4X2 XLX 1/14 Scale Semi Truck - KIT from Tamiya - TAM56350
Version Info: This truck is a KIT. Assembly is required. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
This is a special edition of the 1/14 R/C MAN TGX 18.540 4x2 XLX assembly kit. It comes with body components, which are beautifully pre-painted in Tamiya TS-10 French Blue (clear topcoat applied), with a durable coating applied to protect the paintwork from damage.
Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya MAN TGX 18.540 4x2 XLX is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins one axle supported on a realistic leaf spring and shock suspension. The MAN TGX 18.540 4x2 XLX's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
540-Sized Motor and 3-Speed Transmission The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive the axle. |
| Exceptional Scale Detail Scale details surround this truck for exceptional realism. |
Rear Axle Each axle is supported with leaf spring and shocks. |
| LED Light Buckets You can install your own LED lights (sold separately) to further the scale appeal. |
1/14 Scale This truck comes in an impressive 1/14 scale. Coming in at close to 2 feet in length, it has an ideal on-road presence while being convenient to transport. |
| Add Your Own Electronics and Drive! Once you add your preferred electronics you're ready for those on-road adventures. |
- Exceptional scale detail and realism brings this truck to life on every level
- The realistic interior includes seats and dashboard while metal-plated parts as well as metal transfer emblems enhance exterior detail
- The included coupler enables connection with any currently available Tamiya 1/14 scale trailer
- Cabin tilts forward just like the actual truck
- Metal leaf springs and friction dampers enable realistic suspension movement
- When controlled with a separately available R/C system, the 3-speed transmission enables authentic gear changes while driving
- The model features a realistic body and a 3-axle chassis with durable ladder frame
- Cab, F, H, K, M and CC parts are replaced with pre-painted Gun Metal color parts
- Tamiya MAN TGX 18.540 4X2 XLX 1/14 Scale Semi Truck - KIT
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 6 Cell 7.2V NiMH Brushed ESC
- Standard size servo - we recommend the Hitec HS-311 Plastic Gear Standard Servo
- 6 Cell 7.2V 1600mAh NiMH battery with universal connector
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 3+ HOURS
| Model Scale | 1/14 |
| Length | 458mm / 18.0in |
| Width | 193mm / 7.5in |
| Height | 298mm / 11.7in |
| Weight (No Battery) | N/A |
| Wheelbase | 272mm / 10.7in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | Aluminum |
| Drivetrain | 3-Speed |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | Metal and Plastic |
| Suspension | Leaf Spring |
| Shock Type | Friction Damper |
| Transmission | 3-Speed |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | 1st gear 32.49:1, 2nd gear 17.76:1, 3rd gear 10.66:1 |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Gear |
| Ball Bearings | N/A |
| Brakes | Electronic |
| Electronic Speed Control | 6 Cell 7.2V NiMH Brushed ESC (required) |
| Motor | 540-Brushed |
| Battery | 7.2V 1600mAh (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 1x standard size (required) |
| Radio | 4+ Channel (required) |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Intermediate |
| Assembly Time | 3+ Hours |
| Recommended Environment | On-road, smooth, paved surfaces |
